BrandonLaw Posted May 18, 2020 Posted May 18, 2020 After taking some time off, I decided to update everything to current. This includes VPX, VPM, (SAM,) and PBX. All have updated fine, and works, but strangely my DMD would not display the vPinMame info in PBX. Just stopped with the update. Nothing changed with my settings as it was a linear upate. Did some digging..mainly batch reverting files in PBX down to single files and found the culprit to be Interop.VPinMAMELib.dll. I was on 3.94 and went directly to 4.32. If I use the Interop.VPinMAMELib.dll from 3.94...works fine. It's calling something that I have missed in an update or do not have altogether. Any idea what this particular file is referencing other than VPM which is up to date? (I think 5022 is the current build# from Carny's build thread.)
Tom Speirs Posted May 19, 2020 Posted May 19, 2020 Log and ini please, but I had a look to make sure the files were for the appropriate platform (32 bit/64 bit) and didn't see anything.
