Have an x-arcade 2 player joystick. If i use Mame32 then everything is ok. But if i use the gameex interface, player 1 joystick does not work but the buttons do. The coin button also moves to button 8. It used to work in v3.63 but stopped in v3.64 and 3.70.
Any ideas?
Any ideas?
Found the solution. Need to add the -ctrlr xarcade as a command line option.
How about an option in gameex to choose which input device you are going to use. A ticket box for xarcade, joystick, keyboard etc.
