Everybody needs to send hansolo77 a thank you for contacting me, as I don't really hang out over here ;)
I don't really use GameEx (though that may change after playing with it for a bit), and I don't have a registered version, so I don't know if this will work as is, or if Tom needs to add something into the frontend to make it work.
Anyway, these are the proper image and lay files that "should" work for the vertical games with no bezel (for MAME versions 0.107 or greater). Sample pic attached...
If you're lucky, you can simply unzip them to your media folder and it should work. If it doesn't, then it's on Tom to add the hook.
gameex_vertical_artwork.zip
The famous Mr Do!
Welcome to our boards :) And thanks for the bezel, it's been an ongoing issue for a while here.
Tom should hopefully see this soon and make the proper adjustments. Unfortunately I think the bezel feature is a registered only feature, but Tom may give you a free reg for testing purposes.
Very cool!
Thanks 1000000x. :D
The bezel thing's been driving me nutso. :D
Hey Mr Do!
Thanks so much for this. Your welcome to a free registered version of GameEx from me. Just drop me an email to tom@tomspeirs.com (I need to send the key to a valid email address)..
Thanks again,
Tom.
  TSpeirs said:
Hey Mr Do!
Thanks again,
Tom.
Thanks Mr Do! Thanks Hansolo77!
Heh, I sent him an email last night. Wasn't sure if anybody had done it yet. I just asked him and told him about it. Just checked my email and what do you know? :) Thanks a lot Mr. Do!
nice to see the legendary mr do over here,
maybe defecting to game ex we hopes
hi guys i was wondering if you could please tell what folder i have to extract this file into so it will show up in game ex as my default bezel ive tried to extract it into the media folder and also the media bezel atrwork folder in game ex but to no avail game ex boots back to the front end whenever i try to lauch it any help would be great thanks again!!
jester
jester
I'm not sure, but I think that's for Tom to figure out and include in (hopefully) the next major update to GameEx.
Emph
Emph
thanks Emph,
just curious because i know a few version of mame ago i think everyone up untill 106 this option worked and looked great in game ex just would like to see it again !! ill hold on and wait !! thanks for the reply!
jester :)
Yeah, the vertical artwork doesn't work yet. Tom needs to reconfigure GameEx to look for the .lay file instead of the .art file it used to use. Once that is complete, everything should work fine.
Progress, as always, is most welcome even if it's not all sorted asap. Welcome Mr Do! Hope you enjoy your time with Gamex!
Tom will no doubt sort it soon enough ;)
