I always keep upgrading to the latest and greatest version and for the last three or more updates, the Transparent theme will not work....
It it just me or anyone else having problems too?
All it does is try to load up and then crash and display the error log.
19:48:42.4 5/8/2005: GameEx: Version 3.70: Starting Log
19:48:42.4 5/8/2005: Operating System Platform ID: Win32NT
19:48:42.4 5/8/2005: Operating System Version: 5.1
19:48:42.4 5/8/2005: Running Randomize()
19:48:42.4 5/8/2005: Running Misc startup tasks
19:48:42.4 5/8/2005: Hiding Cursor
19:48:42.4 5/8/2005: Setting Menu types
19:48:42.4 5/8/2005: Opening Configuration File
19:48:42.4 5/8/2005: Getting Configuration Values
19:48:42.4 5/8/2005: Using Theme: Default - Transparent
19:48:42.4 5/8/2005: Checking for alternate Image Directory for Theme: Default - Transparent
19:48:42.4 5/8/2005: Applying Language/Text
19:48:42.5 5/8/2005: Snap Delay set to: 4
19:48:42.5 5/8/2005: Is Media Center running?
19:48:42.5 5/8/2005: Check Media Center Exit/Start Mode
19:48:42.5 5/8/2005: Media Center Mode 0
19:48:42.5 5/8/2005: Get other settings
19:48:42.5 5/8/2005: SlikStik support enabled
19:48:42.5 5/8/2005: Using DirectInput for keyboard input
19:48:42.5 5/8/2005: Launching HideOS.exe
19:48:43.2 5/8/2005: Hiding Taskbar
19:48:43.2 5/8/2005: Start work for Form
19:48:43.2 5/8/2005: Getting Original Screen Size
19:48:43.2 5/8/2005: Loading ICON
19:48:43.2 5/8/2005: Initializing Component
19:48:43.2 5/8/2005: Using General Font: Trebuchet MS
19:48:43.2 5/8/2005: Using Title Font: Trebuchet MS
19:48:43.3 5/8/2005: Initialising DirectDraw
19:48:43.3 5/8/2005: Applying GameEx is Loading Image
19:48:43.3 5/8/2005: ERROR when loading Image. Probably does not exist.
19:48:43.3 5/8/2005: Creating DirectDraw Device
19:48:43.5 5/8/2005: Setting Resolution to 800x600 32 bit color
19:48:44.7 5/8/2005: Creating DirectDraw Surfaces
19:48:44.7 5/8/2005: Creating Primary Surface - Full Screen Mode
19:48:44.9 5/8/2005: Creating Back Buffer
19:48:44.9 5/8/2005: Loading graphic surfaces
19:48:46.0 5/8/2005: ERRORS DETECTED: EXITING
Could anyone help?
Thanks.
Could anyone help?
Thanks.
You need to copy over picturesbak.bmp and radiobak.bmp from the default - default theme into the transparent theme media dirdectory. Also copy over the logos.
