8th May 2005
- GameEx 3.70
  • I think this is pretty strong
    release and a good step forward.
  • The main new features are that
    GameEx now supports title, box, and cartridge artwork for
    console emulators.
  • It also now can show title,
    cabinet, flyer, marquee, and panel artwork for Daphne.
  • If your a newbie or unaware of
    screenshot archive I cant praise this site enough. Go there
    to get your console and daphne artwork.
    http://screenshotarchive.com
  • If enabled audio now plays in
    logos that are videos.
  • In addition to the new image
    paths available, there are two more settings for emulators.
  • Much like with MAME already
    these allow you to launch a command before running a game,
    and launch a command when a game exits
  • The Configuration application
    has been reorganised a fair bit to hopefully make things a
    little easier and less confusing.
  • Robs included BlueEx themes
    will now not show corruption with ArcadeVGA 7000 series
    cards.
  • Radio can now play WMA station
    direct links. Meaning station URLS beginning with MMC:// now
    work.
http://gameex.net
<p><font face="Arial" size="3"><b>8th May 2005</b>
                - GameEx 3.70</font>
                <ul>
                  <li><font size="3" face="Arial">The main new features are that
                    console emulators.</font></li>
                </ul>
http://gameex.net
Tom, this feature, I have added the directories in the configuration, but I noticed that none of the title/box/cart pics load. I assume they would normally load in the standard image window, but I only get snaps, even if no snap exists but a box/title does.
What is the preference of GameEx as to which image it shows? Could it be set to look in order, i.e. no snap, look for title; no title, look for boxart; no boxart, look for cart....
Right now I only see snaps, but I want to get more from this feature.
I think this is as we talked before, its because you have 'show game information' turned off. The images are available after you select a game.
Tom
Oh yeah, I remember now. I didn't realize that feature worked for consoles, I thought it was only for MAME. I prefer not to use that option as it adds an extra step in actually running the game. Oh well, there's always hope for the future.
