hi. after start setup wizard for a detailed parameter config.. all configs disappears... is there  a backup file in gameex ? or which files do i have to rescue from a previous backup???
thanks
Look for a file in the CONFIG directory calledGameEx.UpgradeBackup.ini (or GameEx.UpgradeBackup). It is a backup that is made during the upgrade process. Check the date to see how old it is. If it looks like it isn't too old, copy and rename it to GameEx.ini.
  • Draco1962 changed the title to [RESOLVED] help config disappear
  • Draco1962 locked this topic
