Hi everyone.
I have noticed that all of the Jak_ roms are not showing up in my Mame game list in GameEx.  I have updated to 16.27, updated game list, put file names in the do not filter setting,  changed filter settings, and the issue still persists.  Could the file that is contained inside the .zip be the issue (they all only have one .bin within the zip)?   If so, is there anything else that is being omitted that I have yet to notice.
Thanks for the support.
Cheers.
log.txt GameEx.ini
Hi.
The games are probably flagged as not working. GameEx Arcade edition has some stuff hard coded that regular GameEx and GameEx Evolution do not nd only supports working games.
Cheers.
Tom.
I can see you are using regular GameEx. Did you add the games to the do not fllter list, and update the list again?
Let me know if  so and I will look into those particular games further.
Thank you for getting back to me. I've put the roms into the do not filter list, updated, and they still do not work.  I also updated to 16.28.
I appreciate the support.  Stay healthy.
