I have gameex running through a television. Playing a karaoke song in gameex will not show up on the tv. I know in wmp i had to turn on an option to allow this. Is this a gameex problem?
ling what resolution is your monitor set at right now?
I think 800x600 I could be wrong. It supports up to 1024x768. My desktop is set to 1024 and it works fine.
the reason i ask is i also have my pc running through my tv and ive found at anything higher than 800x600 at 60hz cause my tv to freak out sometimes its kinda funky! try setting your desktop to 800x600 see what happenes
regards
jester
regards
jester
Still no luck. My television shows no sign of being out of sync. What media player does gameex use?
  • 3 months later...
Fixed the issue. The television has to be configured as the Main display. I had it set as clone PC monitor. I do know when playing the CDG files in WMP. I had to turn off use overlays for the television to display.
