hi guysi was wondering if any of the game gods out there can gimme a hand with a config for this emu? i cant seem to get it to work inside game ex works fine outside but once i try to get it to work inside game ex im lost anyone know if SSF has command line support? hope someone can point me the rigth direction it would be a shame if i couldnt get a good saturn emu inside my mame cabinet thanks for the help!
regards,
jester :D
well you Pm me asking how i did it so i replied to it what i have done if it helped you and you feel it was easy to do with how i explained it then paste it here so others can use the info to if they are stuck as well :)
sorry night i tried to make a bat file but i kept getting a runtime error im lost here anyone please help me out??? lol
have you made sure the paths was correct and test the .bat outside GameEx first faster to test that way ...
try and paste your .bat text here as well and what you have written in the GameEx.ini to
heres the bat text
"C:\Program Files\DAEMON Tools\daemon.exe" -mount 0,%1
cd "D:\SSF_007_beta_R6\"
SSF.exe %1
and the pic is of my game ex ini
ran it outside of game ex and got a syntax mount error??
thanks for the help!!
jester
heres the bat text
SSF.exe %1
heres the bat text
SSF.exe %1
jester
heres the bat text
SSF.exe %1
heres the bat text
SSF.exe %1
jester
heres the bat text
SSF.exe %1
heres the bat text
SSF.exe %1
jester
heres the bat text
SSF.exe %1
sorry about triple post lol pc is acting crazy!!!!!!
Now I really don't see the need for batch files, seems like a lot of work thats not needed.
I have my Control Panel Command Line:
SSF.exe
My Control Panel Launch Before:
"C:\Program Files\DAEMON Tools\daemon.exe" -mount 0,"[RomPath]\[RomFile]"
My Control Panel Launch After:
"C:\Program Files\DAEMON Tools\daemon.exe" -unmount 0
And every thing works fine...all CD images are in one folder, with proper naming, the rom filter is set to scan only for the required file to mount the image.
My 2cents tho
PS RC9 is out for SSF
thanks night and nologic got it working you guys are awesome!!! next question does SSF have command line switches to lauch in full screen so that it launches with out my desktop showing inside my mame cab?thanks again
jester
Okay full screen is a simple matter...launch the emu how ever you like...directly or from GameEx....once its loaded press ATL+ENTER this will toggle it full screen...then simply exit it with ESC....next time you launch it...it should be full screen.
Basically SSF use's its last used settings...so if you closed it while it was in a window...it will run next time in a window...if it was full screen...it will launch full screen.
cool i have it launching in fullscreen but when it mounts the image inside daemon tools the window come up in front of the emu letting you know that daemon has mounted the image thus blocking the emu from loading full screen unless you click on it to close and ive tried both show desktop and dont show desktop inside the game ex ini any ideas how to stop daemon from showing what its loading so it doesnt stop the emu from loading propery??
thanks again
jester
Okay this is an issue with Daemon Tools....I've had mixed results...tho with SSF I have never ran into that issue...tho I have done very little thus far with SSF...so my lack of issues carries very little weight. ;)
Any ways if you don't have the Daemon Tools system tray icon showing...launch Daemon Tools from the start menu...so that you can now see the system tray icon.
Right click on the system tray icon and select "Virtual CD/DVD-Rom" then the virtual drive you are using...then click on the sub menu "Set device parameters"
Here make sure that "Auto Insert Notification" isn't checked...then click "OK"
Next right click again on the system tray icon and select "Options" and make sure in the sub menu that "Autostart" is not checked...I'd also suggest making sure "Automount" is also not checked....personal pref tho.
thanks for all the help guys! got it working flawlessly you guys are the bomb! now with the saturn emu it brings the count of emus in my mame cab to over 25 emus in all and over 50,000 games yes that number is accurate lol ive added them up when i was bored! lolthanks again for all your help guys! and tom thanks tom for a great looking front end!
game ex rocks!
regards
jester :D
Your welcome...and tho I may sound like I kind of knocked night's batch scripts...it was his prior postings that got me going in the right direction...so props to him for that...even tho I never stated so prior.
  • 2 months later...
Can SSF be used with Alcohol120?. Inside GameEx ofcourse.
I got ssf working fine but I am having a problem with getting the .cue files to load. Without these I have no music and little sound.
For example I have "Die Hard Arcade.iso" mp3 files are called "Die Hard Arcade 02.mp3" though 41.mp3
They are located in D:\EMULATORS\SSF\roms
Here is my cue file if you could tell me why I get the error "Unable to mount image, File not accessible" in Daemon Tools
FILE "Die Hard Arcade.ISO" BINARY
TRACK 01 MODE1/2048
INDEX 01 00:00:00
POSTGAP 00:02:00
FILE 02.WAV WAVE
TRACK 02 AUDIO
PREGAP 00:02:00
INDEX 01 00:00:00
FILE 03.WAV WAVE
TRACK 03 AUDIO
INDEX 01 00:00:00
track list goes on to 41 I tried switching the FILE line to "D:\EMULATORS\SSF\roms\Die Hard Arcade.ISO" BINARY
With the same results. Thanks for the help
Have you tried directly mounting it with daemon tools?
Right now I have GameEx in a total mess...so can't test directly.
How ever I have mounted a Sega CD game thats in that format...and all went well. There are a few diff's between your layout and mine.
CATALOG 0000000000000
FILE "Bill Walsh College Football (1993)(Electronic Arts)(NTSC)(US)(Track 01 of 16)[!][CDAC-054000 1].iso" BINARY
TRACK 01 MODE1/2048
INDEX 01 00:00:00
FILE "Bill Walsh College Football (1993)(Electronic Arts)(NTSC)(US)(Track 02 of 16)[!][CDAC-054000 1].wav" WAVE
TRACK 02 AUDIO
PREGAP 00:02:00
INDEX 01 00:00:00
FILE "Bill Walsh College Football (1993)(Electronic Arts)(NTSC)(US)(Track 03 of 16)[!][CDAC-054000 1].wav" WAVE
TRACK 03 AUDIO
INDEX 01 00:00:00
As you notice I have a "Catalog" entry...seems like a useless entry...file names used for the wav files are quoted...I wouldn't think this to be an issue unless there is a space in the naming...but who knows. Next I have no gaps between entry's...so basically I'm clueless. ;)
If all else fails you can always fire up Nero and create a single disc image of the game. :(
If I label them as yours is
FILE "Dead Or Alive.iso" BINARY
TRACK 01 MODE1/2048
INDEX 01 00:00:00
POSTGAP 00:02:00
FILE "Dead Or Alive 02.mp3" MP3
TRACK 02 AUDIO
PREGAP 00:02:00
INDEX 01 00:00:00
FILE "Dead Or Alive 03.mp3" MP3
TRACK 03 AUDIO
INDEX 01 00:00:00
FILE "Dead Or Alive 04.mp3" MP3
I get "Unable to mount image. This track file type is currently unsupported" Im using the newest daemon and mounting direct.
Well this is what I came up with when its mp3's.
link 1
link 2
Thank you for taking the time. This did work. Just have to make sure you encode the .Wav files into 44100hz or they will not mount. Thanks again
Yea there is still an issue. Not sure what part of the process I can take care of this or if at all.
For example the BGM is LOUD, much louder than the game sound once you get the cue files running. In die hard arcade all you hear is the music, In options you can set the BGM Vol Level but it does not work even if you put it at zero it still gives max sound. I wonder if there is a trick to turning down the output levels some where during the conversion...
