Hello,
@Tom Speirs when I enable Custom Keyboard Controls in GameEx Arcade, paging key doesn't work properly and acts as "BACK". Do you have some suggestion on how to fix this issue? Thanks.
Hello there,
same problem here, I hoped to find a turn around to solve the issue but I wasn't able to do that, even working on .ini file.
I really hope it can be fixed.
thanks
@Tom Speirs I tested GameEx Standard and GameEx Arcade 16.10 and found that paging via the keyboard and joystick were not working as expected. As aavecone suggested, the paging function for the keyboard causes the menu to go BACK while the paging function for joystick has no effect.
Paging commands for keyboard and joystick are working fine in GameEx Standard 16.10.
thanks for the answer
The problem is that using the paging function it is possible to jump from letter to letter and it is quite helpful, specially in a big folder using an arcade control without keyboard access.
thanks again
