I've been working on ZiNc, NoeGEO, PCengine (booot from CD) WinKwaks ... and come up with some sollutions for ZiNc in order to run the game (as an separate emulator under emulated games) ypu need a bat file that will run the game for an example
aquarush.bat
@echo off
F:\gemes\Emulation\EMUs\ZiNc\zinc 63 -use-.....
end
and config files for renderer and zinc config with path to the romc example "F:\gemes\Emulation\ROMs\ZiNc"
in the settings in Gameex fo command input this "F:\gemes\Emulation\ROMs\ZiNc\bat\[rom].bat
and zinc will run Aqua rush
this is becose ZiNc runs the games by numbers build in the exe
for list uce ZINC --list-games
from the example Aqua Rush is No 63
and that's it for ZiNc :D
soon to follow for other eums B)
does someone have sollution for neogeo, the best eum by me is NeoRageX but I can't launch a game from command prompt (all other emus doe not play all of the roms they need othet rom structure for exzmple nebula needs fthe files to be something_ROM_AC.bin nad my files from the cd that comes with neoragex are something_AC.ROM) :unsure:
ZiNc files added
ZiNc.zip
Magic Engine emulator boot from CD
*emulator fot NEC Turbo Grafx 16
files that you need
> Magic Engine Emulator
> sysgard3.pce (tray googling for it :rolleyes: )
>cd images or CD-s *mine are nrg (NERO images)
>daemon tool (or Alcohol 120%)
> and my files oc course
example of bat file
@ echo off
D:\tools\Daemon\daemon -unmount 0
D:\tools\Daemon\daemon -mount 0, G:\IGRI\EMULATION\ROMs\PCengine\Akumajou_Dracula.nrg
cd G:\IGRI\EMULATION\EMUs\PCengine\PCE
pce.exe syscard3.pce
exit
PCE.zip
