I have turned off all filters in GameEx, but for some reason, none of my MAME roms show up. I have the full 108 list. Am I missing some small option someplace?
Overall, I am blown away by GameEx, as soon as I have the extra funds, I plan on giving
Yes, each time I change anything, I tell it to update
Snap shots of your config will be a big help.
Will take snaps when I get home.
Have you made sure all your paths for Mame are setup correctly in the Config program?
Yes, I use the same Rom path that MAME32 uses
Here is a screen cap of my config for MAME under GameEx
and yes, the path with all my roms is suposed to be ..\roms\roms
Everything looks good. Did you browse for the file directories or input them from memory? try dl mame command line and see if that works. BTW what mame32 version you using? Did you dl the correct dat file for your roms? verify with clrmamepro or similiar?
I downloaded the most current version of mame32, I browsed for the directories.
I'm useing the 0.108 ROMs set directely from pleasuredome, is there a special dat file I need to get for mame32?
