Just a minor thing:
I can't seem to find the correct setting in the Setup Wizard to point GameEx to my GhostScript directory. As a result I'm not able to display manuals.
I could of course change the GS dir as suggested here, but surely there must be a better way. What am I missing?
Thanks!
GameEx.ini log.txt
I think that is a very old post. It may work. If it does, what is the issue?
Which version of Ghostscript are you using?
I doubt its a hardcoded path. Its taken from the registry as far as I know. So change the registry values rather than the paths.
Thanks for hinting me to the registry which solved my problem if only with a workaround.
Somehow GameEx keeps looking for C:\Program Files (x86)\gs\gs\bin\gswin32c.exe, no matter which GS version is installed on my system (I tried GS v9.50 with both the 64 and 32bit builds). I did a registry search for that path with no results. What I did is reinstalling the 32bit GS version to the above path (which includes manually editing the suggested path in the GS installation wizard).
This topic is closed - thanks again!
