Slamit Pinball - Big Score is the only Pinball Software I use that doesn't have Joystick nudge support.
I made this script to add nudge support.
Hopefully this will be useful to someone.
Just set Nudge to run before "Slamit" and run CloseNudge after to exit script
It works by monitoring the X and Y axis. Sending keyboard inputs that are used in game for nudge.
you can edit the source to change varibles if need be. Use joysticktest.exe to see what varibles you need.
Joysticktest.exeFetching info... Nudge.exeFetching info... CloseNudge.exeFetching info... Nudge.ahkFetching info...
