just installed for try-out this front end. automatically installed necessary framework files even this frameworks already installed.
given this error. Software didnt run on first try.
help pls.
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.ArgumentException: An item with the same key has already been added.
   at System.Collections.Generic.Dictionary`2.Insert(TKey key, TValue value, Boolean add)
   at Headsoft.Engine.BitmapFont.ReadXml(String fileName)
   at Headsoft.Engine.BitmapFont.Initialize(String fontFolder, String fileName, Single sizeInPixels, FontStyle fontStyle, ColorNode textColor, ColorNode[] strokeColorArray, ShadowNode shadow, String charString)
   at Headsoft.Engine.BitmapFont.Initialize(String fontFolder, String fileName, Single sizeInPixels, FontStyle fontStyle, ColorNode textColor, ColorNode[] strokeColorArray, ShadowNode shadow)
   at Headsoft.Engine.TextObject.a(Device A_0)
   at Headsoft.Engine.TextObject.ResourceLoad(Device device)
   at Headsoft.Engine.Layout.ResourceLoad(Device device)
   at Main.OnLoadLayoutLoaded(Object sender, LayoutEventArgs e)
   at Headsoft.Engine.Layout.Create(LoadLayoutEventArgs loadLayoutEventArgs)
   at Headsoft.Engine.Layout.b(Object A_0, RunWorkerCompletedEventArgs A_1)
   at System.EventHandler`1.Invoke(Object sender, TEventArgs e)
   at Headsoft.Engine.PsdParser.a(Object A_0, RunWorkerCompletedEventArgs A_1)
************** Loaded Assemblies **************
mscorlib
    Assembly Version: 2.0.0.0
    Win32 Version: 2.0.50727.8793 (QFE.050727-8700)
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v2.0.50727/mscorlib.dll
GameEx Evolution
    Assembly Version: 1.0.0.0
    Win32 Version: 1.0.0.0
    CodeBase: file:///D:/_tools/emulation/GameEx%20Evolution/Bin/x64/GameEx%20Evolution.exe
System.Windows.Forms
    Win32 Version: 2.0.50727.5491 (Win7SP1GDR.050727-5400)
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
    Win32 Version: 2.0.50727.8791 (QFE.050727-8700)
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
    Win32 Version: 2.0.50727.5495 (Win7SP1GDR.050727-5400)
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
Headsoft.Engine
    CodeBase: file:///D:/_tools/emulation/GameEx%20Evolution/Bin/x64/Headsoft.Engine.DLL
Headsoft.Tools
    CodeBase: file:///D:/_tools/emulation/GameEx%20Evolution/Bin/x64/Headsoft.Tools.DLL
Headsoft.FrontEnd
    CodeBase: file:///D:/_tools/emulation/GameEx%20Evolution/Bin/x64/Headsoft.FrontEnd.DLL
SlimDX
    Assembly Version: 2.0.13.43
    Win32 Version:
    CodeBase: file:///D:/_tools/emulation/GameEx%20Evolution/Bin/x64/SlimDX.DLL
msvcm90
    Assembly Version: 9.0.30729.7523
    Win32 Version: 9.00.30729.7523
    CodeBase: file:///C:/Windows/WinSxS/amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.7523_none_08e1eaf5a83f8ea2/msvcm90.dll
Headsoft.Image
    Assembly Version: 1.0.6559.1852
    Win32 Version:
    CodeBase: file:///D:/_tools/emulation/GameEx%20Evolution/Bin/x64/Headsoft.Image.DLL
Headsoft.Video
    Assembly Version: 1.0.6537.39778
    Win32 Version:
    CodeBase: file:///D:/_tools/emulation/GameEx%20Evolution/Bin/x64/Headsoft.Video.DLL
System.Xml
    Win32 Version: 2.0.50727.8773 (QFE.050727-8700)
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
System.Configuration
    Win32 Version: 2.0.50727.5483 (Win7SP1GDR.050727-5400)
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
v5ugtrts
    Assembly Version: 0.0.0.0
System.Management
    Win32 Version: 2.0.50727.8766 (QFE.050727-8700)
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Management/2.0.0.0__b03f5f7f11d50a3a/System.Management.dll
ypkhi7sl
zh_qd1oy
wxjtmgog
i8yglzbe
Headsoft.DriveInfo
    Assembly Version: 1.0.6535.17563
    Win32 Version:
    CodeBase: file:///D:/_tools/emulation/GameEx%20Evolution/Bin/x64/Headsoft.DriveInfo.DLL
System.Web
    Win32 Version: 2.0.50727.8762 (QFE.050727-8700)
    CodeBase: file:///C:/Windows/assembly/GAC_64/System.Web/2.0.0.0__b03f5f7f11d50a3a/System.Web.dll
lweix_0v
dfjofozj
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
    <system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
Looks like an issue loading a font. What is your system spec?
Please try deleting the UserData folder and rebooting,
I also noticed you seemed to install to the non default location. So it could be a user rights issue.
