What emulator for Super Nes?
Guest Evil
Hi everybody!!! What emulator u use to run snes games?
If its posible, let my the config for the emulator too!!
Thanks a lot!!
Guest Evil
Ok, im using this emulator but the problem is that it apears in a little screen in the middle of my monitor, and joypad not work.
If i execute zsnes whitout gameex, the screen is full and joypad works correctly!!
What can i do to repair this?
Thanks a lot!!
Hi I use snes9x
Most EMU once first open up open in small window
FOR ZNES yes i download it just to help you out but that what we do here help each other out
look under config video and set it to the one you like
You have to config controller look under config input the 1 set keys/joystick then hit set then push the ksy/joystick for each one
THIS ONE IS EASY TRY N64 ON PLAYSTATION 2 BUT IT WORK
I use a use a playstation 2 contorller via usb
Have use
Guest Evil
Hi I use snes9x
Have use
Thanks a lot!!!
It works!!
