For all ordinary emulators, there is an option in the Setup Wizard Advanced Emulator Setup for Advanced Config.  In here I can set, for example, whether the escape key closes the process.  In the MAME Settings page, however, there is no option to set Advanced Config.  Is there any other place where I can configure how the MAME emulator's exit process is managed?  Basically, I'm just trying to prevent return to the front end until the exe process exits on its own as I can with other emulators by setting the aforementioned switch to false.
Perfect!  Turning off global Esc exit under input settings was exactly what I needed.  Thanks Tom!
