Got the construction phase of my 2nd cab complete so before I started my final tweeking of the all the software for machine startup and shutdown I figured I would get the latest version of gameex.I went from v5.88 to the latest 6.76 and have noticed a couple things that seem to be acting up.Once the screensaver feature kicks in it seems to take a long time to get it back out of screensaver mode by hitting a button.Then once you get back to the game menu (all mame games),it will show the correct total number of games but if you start paging through the list it will only go about half way through the list and then return to game 1.You have to go back to the main menu and reselect all mame games again before you can scroll through the entire list of games.
You probably need to update your Mame list as the newer versions of GameEx uses list caching to speed things up.
There are obviously many new features since your last update, so it's hard to know what could be causing the issue. Tom often turns on new features by default so perhaps it is a new feature causing the problem. But I would try updating the list to refresh your data files first.
