Hi All,
My Gamex stopped working and i have tried reinstalling .net and gamex but to no avail, i cannot run either the config or the gamex i get the following error message.
Application has generated an exception that could not be handled.
Process id=0xdf4 (3572), Thread id=0x444 (1092).
Any help wuld be appreciated.
I have attatched the log, nothing much in it.
Regards
Trojan
Hi All,
Regards
Trojan
Uninstall GameEx then delete the GameEx directory completey (C:/program files/gameex). Then try installing again.
I also notice your running an older version. Any reason why you can't upgrade to the latest?
Hi Tom,
I was running the latest version but to try and eliminate things i installed an older version, will try the suggestion and post the result.
Thanks.
Trojan
Tom,
Tried deleting the directory and installing latest version still the same error.
Log file attached.
Regards
Trojan
Hi,
Please replace GameEx.exe with the one in the attached zip and post the log.
Can you also have a think about what might have changed on your system? Such as new software, drivers, patches, upgrades?
I think I know where its failing and others have had similar problems with the type of code GameEx is running at that stage. I still dont know what causes it, and the only way this has ever been fixed is to do a compolete reinstall of the OS :(
Please post the log of this version anyway. It might be something else.
Thanks.
Tom
GameEx.zip
Hi Tom,
This all seemed to happen when i installed 3.61 and updated .net also, since then it never worked .
I have copied the new exe file and posted the log as requested.
Regards
Trojan
Unfortunatly as I suspected. No current solution exists that I am aware of other than rebuilding your PC OS.
Sorry Trojan.
