Hello, I just installed a Servostik in my cab. While I can get it to switch between 4 and 8 way using Ultimarc's Joytray app, I'm having some issues getting it to work in Gameex.
Version 1.3 doesn't show up in the setup plugins list when I dump the files into the plugins root directory.
If I do the same with version 1.22, the plugin is displayed but when I fire up a game nothing happens. The log file does indicate something is awry.
As always thanks for looking into this. Hopefully we can get 1.3 visible and working.
log.txt GameEx.ini
