hi, trying to get a photo viewer to go fullscreen then scroll down for each photo.
ENTER, CTRL+DOWN, CTRL+DOWN
whatever i try e.g.
{ENTER}^{DOWN}^{DOWN}
or
{ENTER} ^{DOWN} ^{DOWN}
{ENTER}^{DOWN 2}
or even
{ENTER}{DOWN}{DOWN}{DOWN}{DOWN}{DOWN}{DOWN}{DOWN}{DOWN}{DOWN}{DOWN}{DOWN}{DOWN}{
OWN}
(wrong key but would do something noticeable)
always results in only the first ENTER working and ignoring everything else.
im using waitbeforekeys for 2000 aswell as it needs this to start
app is Faststone Image Viewer btw.
thanks
using 6.76 btw
Perhaps there needs to be a delay between the {ENTER} and the keypresses?
Just as a note to Tom, to emulate the pause between a keypress so it's exactly the right speed I use the following C code to calculate the time to wait.
DWORD kbs;
SystemParametersInfo(SPI_GETKEYBOARDSPEED, 0, &kbs, 0);
kbs += 2;
int KeyDelayValue = 1000/kbs;
so there's currently no way to put pauses in between keys?
related to the same problem,
1) if i update a dirs.map while gameex is running, is there any way to get gameex to re-read the file? ideally i would like it to check the map file last modified every time you open that list! i need this or similar because i update things in the background, after gameex starts. making gameex wait until everything is done is out of the question as it would take ages to start up :/
sorry this is a non issue, gameex apprently is checking every time the list is loaded? :)
2) is there no way to get gameex to *not* sort lists alphabetically? even when i sort my map file lines myself, gameex puts it back in alpha order. gah!
er thanks Tom if you're reading.
