Help?
01:26:58.6 9/1/2006: Playing intro sound file
01:26:58.6 9/1/2006: Initializing MCE Remote
01:26:58.7 9/1/2006: Initialization OK! Starting GameEx!
01:26:58.7 9/1/2006: Testing Main Loop Once: Processing Frame
01:26:59.1 9/1/2006: Testing Main Loop Once: Main Loop ran successfully
01:27:41.3 9/1/2006: 21 Consecutive Exceptions Occured: Exiting
01:27:41.3 9/1/2006: Error in the application.
01:27:41.4 9/1/2006: at Microsoft.DirectX.DirectDraw.Surface.DrawInternal(tagRECT* destRectangle, Surface sourceSurface, tagRECT* srcRectangle, DrawFlags flags, DrawEffects& bltEffects)
01:27:41.4 9/1/2006: at Microsoft.DirectX.DirectDraw.Surface.Draw(Rectangle destRectangle, Surface sourceSurface, Rectangle srcRectangle, DrawFlags flags)
01:27:41.4 9/1/2006: at GameEx.GameEx.mainform.DrawMenuImages(Boolean over)
01:27:41.4 9/1/2006: at GameEx.GameEx.mainform.DisplayFrame()
Is it something I did... Or didn't do? :(
Hey Adultery,
Are you using the theme you posted in the feature requests? If so it looks like the box for the database/create snaps might be too small, try replacing the values in the ini with the ones from the custom V2 ini.
Or if you have changed the intro sound, try restoring it to the default.
Any use?
p.s. you can move the media controls by using the arrows, or by entering in a new value, you just cant drag them. However; the now playing text will remain in the same position. (if you do move the controls away from the top of the screen, you need to set the toolbar to always show)
Amos, you're pretty much the man. Thank you! My menu was like 5 px too small. :)
