Please help me!! Gameex dont run!!
Guest Evil
Hi everybody, and first of all, excuse my bad english, im from spain.
I downloaded gameex and configure it. I have mame32 and when i start the aplication gameex appears a message saying:
Gameex.exe . Servicios de depuracion de common language runtime
La aplicacion genero una exepcion que no se pudo controlar.
id. de proceso=0x264 (612), id. de subproceso=0x284(644)
haga clic en aceptar para terminar la aplicacion.
haga clic en cancelar para depurar la aplicacion.
Please, any sugerencies? It seems a memory error, but i have a amd athlon xp 3000 processor and 1gb of ram. I think hardware is not the problem.
Please, some help!!! Thanks a lot.
Hi Evil, i am not too sure. I was thinking the .net framework was not installed but you say you can run the configuration application?
All I can suggest is try uninstalling the .net framework and reinstall it (direct from Microsoft).
Can you try 3.64 (just uploaded)
Guest Evil
First of all, thanks a lot for your fast replies!!! You are a very wonderfull people!!
In answer to Tspiers, yes i can run configuration tool, but when i try to run aplication it crash with that message error.
I tryed 3.64 version and i have the same problem. I try to install .net framework beta 2.0 but it still failing.
The problem its in my computer because i try it in a laptop and it work so well. Its a fantastic program!!!
How i do to uninstall .net framework and reinstall it?
Thanks a lot.
-=Evil=-
P.D.: Sorry for my very, very bad english!!
Please post your log file. It may shed some light.
Guest Evil
Sorry, but i cant, because i cant run gamex!!!
Now im playing gamex in a laptop and its so pretty!!!
Thanks for your help!!!
Can you post the log anyway? Or do you mean the log file just shows the default one from the install (which is the last one from my development system)?
If there is no log at all. It must be something to do with the framework and your system, rather than GameEx.
You can uninstall the framework under add/remove programs in windows.
You could try uninstalling it, then getting the version from MS (dont use the GameEx install)
