21:08:48.9 8/31/2006: GameEx: Version 6.76: Starting Log
21:08:48.9 8/31/2006: Operating System Platform: Win32NT
21:08:48.9 8/31/2006: Operating System Name: Windows XP
21:08:48.9 8/31/2006: Operating System Version: 5.1.2600
21:08:48.9 8/31/2006: ERROR: An error occured while checking for previous instance of GameEx
21:08:48.9 8/31/2006: This can be caused by a bad windows or .net framework install.
21:08:48.9 8/31/2006: GameEx will likely function incorrectly as it cannot check for running processes
21:08:48.9 8/31/2006: GameEx will now exit with errors
21:08:48.9 8/31/2006: This type of error normally requires a new windows install
21:08:48.9 8/31/2006: and there is no known fix
21:08:48.9 8/31/2006: Try uninstalling .net Framework 1.1 and ensure 2.0 is installed
21:08:48.9 8/31/2006: Check any software either malicious or genuine
21:08:48.9 8/31/2006: that may stop scanning for processes
21:08:48.9 8/31/2006: Error: 1 - Application-defined or object-defined error.
21:08:49.0 8/31/2006: ERRORS DETECTED: EXITING
this just happened out of nowhere, i was using an older version and this system never goes online. so i updated to new version hoping to resolve it and did exactly what it says and now have both framework 1.1 and 2.0 installed and still same error. i would hate to format my hardrive, i have waaay too much customizing going on to have to redo everything. please help! hoping that maybe there is a known fix by now.
you can copy the Gameex folder to another hard drive and format, after format install gameex then copy the gameex folder you copied before format and replace the newly installed one this will work i have done it a few times
you need to install gameex again simply to add a few regestry edits
bare in mind this will only fix the problem if it is windows :P
I dont think its gonna do it, but you installed 2.0 of .net but did you uninstall 1.1?
yea, thats what i did first, uninstalled 1.1, then installed 2.0 from the microsoft website version x86. and with same errors. then put 1.1 back directly from your link on the downlaod page leaving 2.0 still installed.
-i''ll mess around some more with which .net version im using but i think i already tried every combo.
ok, oddly enough it mustve been .net 1.1
-i simply uninstalled 1.1 again and 2.0, searched out all related files and deleted them, re-installed 2.0 and it works great now. wierd it didnt workd the first time i did that. im thinking my first downlaod of 2.0 mustve got interupted or something.
-anyways, back to some hardcore game play!! thanks for the advice.
