Seems this version rather than just simply ignoring a bad Emu being enabled...it actually exits.
Not sure if this is the best behavior...tho I honestly can not say its wrong ether. ;)
*Update*
LOL this is a ball buster now...hehe any thing that I have thats in the config wrong its calling bullshit on. ;)
Any ways log file:
07:32:19.2 8/31/2006: GameEx: Version 6.76: Starting Log
07:32:19.2 8/31/2006: Operating System Platform: Win32NT
07:32:19.2 8/31/2006: Operating System Name: Windows XP
07:32:19.2 8/31/2006: Operating System Version: 5.1.2600
07:32:19.2 8/31/2006: Checking for versions of .net Framework installed
07:32:19.2 8/31/2006: .net Framework 1.0 Installed
07:32:19.2 8/31/2006: .net Framework 1.1 Installed
07:32:19.2 8/31/2006: .net Framework 2.0 Installed
07:32:19.2 8/31/2006: AMD Athlon 64 Processor 3200+
07:32:19.2 8/31/2006: 2.01Ghz
07:32:19.2 8/31/2006: Running Randomize()
07:32:19.2 8/31/2006: Checking for applications to Launch On Startup
07:32:19.2 8/31/2006: Initialising Video/MNG DLL's
07:32:19.2 8/31/2006: Running Misc startup tasks
07:32:19.2 8/31/2006: Setting Menu types
07:32:19.2 8/31/2006: Opening Configuration File
07:32:19.2 8/31/2006: Getting Configuration Values
07:32:19.3 8/31/2006: Using Theme: Default - MCE Glossy
07:32:19.3 8/31/2006: Checking for alternate Image Directory for Theme: Default - MCE Glossy
07:32:19.3 8/31/2006: Launching HideOS.exe
07:32:19.3 8/31/2006: Hiding Taskbar
07:32:19.3 8/31/2006: Is Media Center running?
07:32:19.3 8/31/2006: Checking/Creating LCD Registry values
07:32:19.3 8/31/2006: Check Media Center Exit/Start Mode
07:32:19.3 8/31/2006: Media Center Mode 2
07:32:19.3 8/31/2006: Text/Language: English
07:32:19.3 8/31/2006: Applying Language/Text
07:32:19.3 8/31/2006: Snap Delay set to: 2
07:32:19.3 8/31/2006: Get other settings
07:32:19.4 8/31/2006: Set: Find emulator artwork on best match basis
07:32:19.4 8/31/2006: Start work for Form
07:32:19.4 8/31/2006: Getting Original Screen Size
07:32:19.5 8/31/2006: Loading ICON
07:32:19.5 8/31/2006: Initializing Component
07:32:19.5 8/31/2006: Initialising Bass Audio Library
07:32:19.7 8/31/2006: Loading default loading screen
07:32:19.7 8/31/2006: Loading Custom Emulators
07:32:19.8 8/31/2006: Loading Emulator 1: Nintendo GameCube
07:32:19.8 8/31/2006: Error: Emulator_1: WorkingPath Does Not Exist
07:32:19.8 8/31/2006: --Please correct the error above for this emulator or disable the emulator.
07:32:19.8 8/31/2006: ---------------------------------
07:32:19.8 8/31/2006: Error: 5 - Procedure call or argument is not valid.
07:32:21.3 8/31/2006: ERRORS DETECTED: EXITING
This "feature" is not specific to this version. I cannot honestly tell you what rev I started using but I know that if you enabled lets say Mame or Daphne and the application path was wrong it'd exit just like what you're seeing. You're going to have to take your time when you put the application paths in or you'll be seeing alot of this happening. Maybe Tom can change this behaviour and maybe create a "Log file dump" but yet allow GameEx to load up anyway regardless of user input errors?? Heck ....forget the error dump file and incorporate the windows feature of a pop up error dialog box! Click ok and GameEx doesn't exit. I dunno just my thoughts.
I think this is the intended behaviour of GameEx to do that. It's debatable as to whether or not it should function this way, but there are positives for it being this way to. It does force the user to have a correct working directory for every enabled emu.
I think a better way to handle this would be to allow GameEx to launch but upon selecting the emulator an error message pops up indicating the working path is incorrect. In a way using the log file method makes debugging easier though, since making a screenshot of an error message is more difficult than pasting the log text file.
It always used to error on startup if an emulator was setup incorrectly to the extent that it just would not work.
What I did do is try not doing this and just disabling the emulator in the versions last week.
I then realised that non experts and newbies would have absolutely no idea why there emulators where not showing up, so decided to put it back how it was. Headkaze is absolutely correct that there could be a better way, and I like his suggestion. but for now until I get round to it I think this is best.
