Hi all,
had a HDD Crash now, and before an older PBX Version, i made Screenshots with S and B for PF/BG,
but now, i only can set 1 Key for Screenshot and only get PF Screen, how can i make BG Screens now ?
Latest PBX Version on Win 10 …
But Maybe i missunderstand, or didn't explained it Right:
i use directb2s with Tables, of Course - but i want to have PF and BG Images in PinballX,
so in the older Versions i pressed S and B, and got Images in /Screen Grabs and in /Screen Grabs Backglass,
then i moved the Images to /Table Images and /Backglass Images - to have it in PinballX.
i only don't use directb2s while Browsing through Tables - because i want to see my Images.
FYI so with Key S - i still get PF Screen, and not the BG ... i don't use Video and directb2s in FrontEnd ... so i still want to have a BG Image,
it was possible in prev. Versions with B ... so now, i should have both with Key S ?
Ive looked into it. This can be caused when Hide Backglass is not set for a table or because PinballX just captures nothing which can happen if a display uses DirectX.
I suspect it is the former.
