Vector games not launching but will in MAME32
Guest Archived From Old Forum
Sorry, that was not all that helpful.
If your using an ArcadeVGA card check the Vector res settings. If your not Create or modify your MAME vector.ini file. If you edit the run last game file, you should see what command line options GameEx is using to launch the game. If its a MAME issue, try www.mameworld.com for some more guidance.
Thanks,
tom.
Hi,
It does not sound like its anything to do with GameEx. Have you checked your mame.ini file?
Try selecting Run Last Game from the GameEx programs group. If it does the same thing its definitely not GameEx.
I have the latest GameX (as of today)...I think 3.2 using it on a
Wells Gardner D9200 monitor.
None of the VECTOR games like Star Wars, etc... display...they
always generate an OUT OF RANGE on the monitor
MAME32 seems to work fine so I know the monitor is good...just need
to know what command lines to run so the VECTOR games will not go
out of range.
Thanks!
Thanks,
tom.
Hi,
out of range.
Thanks!
