I can not find in gameex evolution the location where I can make the settings of the button mapping program called Xpadder. I have not found an executable to configure the xapdder plugin. If there is no such program on the frontend, is there a similar one that can be used? Or some way to set up individual joysticks?
It may seem silly but where are the settings to enter the path of the videos and box of the emulator that we configure?
I will eventually be porting my plugin over once the ability is added to do so. Right now there's no plugin support in Evo IIRC, @Tom Speirs can correct me if I'm wrong of course.
The plugin support (called "Extensions") is in there I just don't think the example code is hosted anywhere yet. Message me and I can send it to you if you like.
Challenge accepted! I'll hit you up here in a bit.
