[Help?] Setup Wizard - Auto Asset Download not saving my login info?
Hello All,
I am a GameEx Evolution newcomer, and am very excited to find this project.  Obviously a ton of work has gone into it, and thanks to everyone involved.  I am usually pretty fluent with most things of a computer nature, but I am having a bit of an issue with the GameEx Evo setup wizard.  The Automatic Asset Download section of it.  I have registered an account with EmuMovies.com, have verified that account, and can log in and log out again repeatedly on the website with no trouble.  However, with the GameEx Evolution setup wizard (v3.3.0) on that section when I input my username and password, it does not save my information.  When I hit either the forward or back arrows (at the bottom right of the wizard window) to go the next screen, and then go back to the Auto Asset Download screen - my info is always blank again.  It is not being saved.  Conversely - on the previous page (the GameEx Online) page my username & password are saved just fine, no problem.
Can anyone shed some light as to why the Auto Aseet Download is not saving my info for EmuMovies.com?  I have tried using both my "username" and my email address, whatever I input is immediately blanked out and deleted as soon as I hit the forward or back arrows in the wizard.  And yes, it is set to "enable".
Thanks much,
AirMurdock
It will be fixed for the next release. In the meantime you can either create the "Emumovies" registry key in current user - software or install the emumovies sync utility which will do this on installation.
