Hello all, I have recently setup GameEX Evolution and my Mame games are running great. I setup 2 emulators (NES RetroArch and Sega Geneisis RetroArch) and both run wit no issues when Launch Random is selected from the Wizard but when I try loading the game list from within Evolution I get the following error, see below. I cannot for the life of me figure out where the issue is. Any help will be greatly appreciated.
Thank you,
Zygon
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.NullReferenceException: Object reference not set to an instance of an object.
   at Main.TryAddGame(GridObject gridObject, GameNode game, ItemList itemList, AssetPath assetPath)
   at Main.GetSystemGameList(BackgroundWorker backgroundWorker, GridObject gridObject, ItemList itemList, SystemNode system, List`1 gameList)
   at Main.UpdateItemList(BackgroundWorker backgroundWorker, SystemNode system, GridObject gridObject, GameListType gameListType)
   at Main.l.h(Object A_0, DoWorkEventArgs A_1)
   at System.ComponentModel.BackgroundWorker.WorkerThreadStart(Object argument)
************** Loaded Assemblies **************
mscorlib
    Assembly Version: 2.0.0.0
    Win32 Version: 2.0.50727.8922 (WinRelRS4.050727-8900)
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v2.0.50727/mscorlib.dll
GameEx Evolution
    Assembly Version: 1.0.0.0
    Win32 Version: 1.0.0.0
    CodeBase: file:///C:/GameEx%20Evolution/Bin/x64/GameEx%20Evolution.exe
System.Windows.Forms
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
Headsoft.Engine
    CodeBase: file:///C:/GameEx%20Evolution/Bin/x64/Headsoft.Engine.DLL
Headsoft.Tools
    CodeBase: file:///C:/GameEx%20Evolution/Bin/x64/Headsoft.Tools.DLL
System.Management
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Management/2.0.0.0__b03f5f7f11d50a3a/System.Management.dll
Headsoft.FrontEnd
    CodeBase: file:///C:/GameEx%20Evolution/Bin/x64/Headsoft.FrontEnd.DLL
System.Xml
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
System.Configuration
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
SlimDX
    Assembly Version: 2.0.13.43
    Win32 Version:
    CodeBase: file:///C:/GameEx%20Evolution/Bin/x64/SlimDX.DLL
msvcm90
    Assembly Version: 9.0.30729.9415
    Win32 Version: 9.00.30729.9415
    CodeBase: file:///C:/Windows/WinSxS/amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.9415_none_08e0c10ba840a28a/msvcm90.dll
Headsoft.Image
    Assembly Version: 1.0.6559.1852
    Win32 Version:
    CodeBase: file:///C:/GameEx%20Evolution/Bin/x64/Headsoft.Image.DLL
Headsoft.Video
    Assembly Version: 1.0.6537.39778
    Win32 Version:
    CodeBase: file:///C:/GameEx%20Evolution/Bin/x64/Headsoft.Video.DLL
lbciwrpk
    Assembly Version: 0.0.0.0
mlnan42r
System.Web
    CodeBase: file:///C:/Windows/assembly/GAC_64/System.Web/2.0.0.0__b03f5f7f11d50a3a/System.Web.dll
r-cfzewa
cikm8unq
byzwjqam
Headsoft.DriveInfo
    Assembly Version: 1.0.6535.17563
    Win32 Version:
    CodeBase: file:///C:/GameEx%20Evolution/Bin/x64/Headsoft.DriveInfo.DLL
i7azirb0
owbqvfrs
System.Data.SQLite
    Assembly Version: 1.0.102.0
    Win32 Version: 1.0.102.0
    CodeBase: file:///C:/GameEx%20Evolution/Bin/x64/System.Data.SQLite.DLL
System.Data
    CodeBase: file:///C:/Windows/assembly/GAC_64/System.Data/2.0.0.0__b77a5c561934e089/System.Data.dll
System.Transactions
    CodeBase: file:///C:/Windows/assembly/GAC_64/System.Transactions/2.0.0.0__b77a5c561934e089/System.Transactions.dll
System.EnterpriseServices
    CodeBase: file:///C:/Windows/assembly/GAC_64/System.EnterpriseServices/2.0.0.0__b03f5f7f11d50a3a/System.EnterpriseServices.dll
qbd01xtu
jf2x5ggh
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
    <system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
