[RESOLVED] Exits on selecting system .net versions
Having problems on new installers when selecting system with enter.  As soon as I try to view different system it exits to windows.  Log files attached.
Last good build for me was 3.13 - after this problems.
error?
20:43:49.3  08/09/2018:  Started
20:44:21.1  08/09/2018:  Error. Exiting
20:44:21.1  08/09/2018:  Select
20:44:21.1  08/09/2018:  Draw failed
20:44:21.1  08/09/2018:     at SharpDX.Direct3D9.Font.DrawText(Sprite sprite, String text, RawRectangle rect, FontDrawFlags drawFlags, RawColorBGRA color)
20:44:21.1  08/09/2018:     at SharpDX.Direct3D9.Font.DrawText(Sprite sprite, String text, Int32 x, Int32 y, RawColorBGRA color)
20:44:21.1  08/09/2018:     at Direct2d.CFont.Draw(String Text, Single x, Single y, Int32 Height, Boolean Center, Color color, Single Scale, Boolean JustMeasure, Boolean NoMeasure, Single Rotation, Boolean Rotate)
20:44:21.1  08/09/2018:     at Direct2d.CFont.Draw(String Text, Single x, Single y, Int32 Height, Boolean Center, Color color)
20:44:21.1  08/09/2018:     at PinballX.FrmMain.ak()
20:44:21.1  08/09/2018:     at PinballX.FrmMain.aw()
20:44:21.1  08/09/2018:     at PinballX.FrmMain..ctor()
20:44:21.1  08/09/2018:  Disposing Plugins
20:44:21.1  08/09/2018:  Showing Taskbar
20:44:21.1  08/09/2018:  Unhiding Mouse Cursor
20:44:22.0  08/09/2018:  Bye
log.txtFetching info...
[SETTINGS].logFetching info...
PinballX.iniFetching info...
Can you be a bit more specific please. Thanks.
Also check that you have no empty game names or descriptions.
Thanks.
It might be an empty string issue which might be fixed in 3.23. Available in a few minutes.
Hi Tom
all resolved now thanks, I have corrected any blank descriptions in settings ( favourites etc ) and installed latest version - working perfect again.
I would like to say how appreciative I am that you wrote this fantastic software.
  • Draco1962 changed the title to [RESOLVED] Exits on selecting system .net versions
  • Draco1962 locked this topic
