What kind of Min req's are we talking about here? and or what is everyone  else runnin with this Fe.
Thx
-d88
'Minimum requirements' you already have, and there on the web site.
Browse the forum and find out what people are using to get a better idea if people dont respond to this. I am still trying to get a better idea myself. Once I have more info I will post on the web site.
Its impossible to know how fast GameEx will run on as it depends on Hardware your Software, your OS, your Drivers, and how much you have tuned your PC, and know about PC's.
Ive had it grind to a crawl on 400Mhz PC but run OK on a 550Mhz Compaq Laptop and play all the old skool games. Others have pretty good results on an 800Mhz, as have I. You say it runs badly on a 1.2. So its hard to anwser.
I'd say anything above a 2.2Ghz with a decent video card and 512MB
and it will run at full speed, so 'recommended' requirements would be that.
I have a
P4 1,5 GHz, 256 MB Ram, ArcadeVGA (ATI 9200) on a cheap and very slow Fujitzu Mainboard (compared to an ASUS) with a 5400Rpm HD.
It runs very fine (no glitches) using Windows XP both in 640x480 and 640x288, but i will change it to Windows 2000 to gain a little bit more speed.
I use an Ipac4 and OptiPac. For my main Controls.
Ah... forgot: generic (from windows) AC97 sound drivers. VideoDrivers from Ultimarc (ArcadeVGA).
CU Cupid
