i have rip cd enabled but when i inset a cd nothing happens.
i must be doing something wrong.
any ideas.
thanx gerble1000
any ideas.
thanx gerble1000
Did you select the playlist menu and click rip the cd?
ah no i didnt. cheers
ive just tried and there isnt an option for ripping there ??
and when i downloaded the newest gamex this morning i couldnt download the themes, it got to about 17mb and had an error message.not sure what it said .some about connection with server i think.
i tried this three times and stops at the same place??
Are you a registered user, if not you dont have cd ripping.
Problem with connection was temporary, thats how the internet is.
i am a registered user i.e i have donated.
fair enough connection sometimes messes up i just thought maybe its not showing the rip button is because i dont have the theme?
am i going to the right place
multimedea
jukebox
playlist/more
and then i get a list of five
multimedea
jukebox
playlist/more
Yeah it should be there. Is the cd playable in windows media player and showing the track and album information?
yes
and i am using the latest media player 10
unfortunatly the cd ripping option is'nt available on the new gameex neither. 6.58.
is anyone else haveing this problem.
i still am unable to rip a cd with this version 6.65 of gameex.
i cant be the only one??
i just dont get the option to rip a cd , and yes cd ripping is enabled and i am a registered user because the nag screen has gone .
HELP
Same as m8 no cd ripper in juke box, and im a registered user, and it is enabled in gameEX.
Leon.
im still not getting the rip menu on version 6.67.or on version 6.68
Thats because I have not looked at it yet. Give me a chance.
How many CD/DVD drives do you have in your machine, and is your machine connected to the internet, and is it an original shop bought cd?
sorry im not trying to push you.
i have a laptop and a computer.
both with 1 cd drive
the cd's im using to try are originals i.e nickelback silver side up and hayley westenra pure.
and both machines are connected to the internet.
thanx gerble1000
sorry tom not pushing its dun when its dun, i no you have alot on, so good luck!
your still the best don't worry!.
leon.
