Hello. I'm new at game Ex, but I love it sop much I had to buy the lifetime subscription   :<)
I was wondering if anyone has ever seen this. I searched all the forums and found how easy it is to setup this analog joystick by using the set49mode.exe lines in Tounces directions below.
It still will not work, so I put a pause command after the runitgame.bat file where it runs the setup command and I get the rror:
Active code page: 65001
GPWIZ49.exe path not set
Press any key to continue . . .
I can copy the line "C:\set49mode\set49mode.exe [ROM]" line on my run command prompt in Windows 7 and it works fine. I confirmed I have the Path variable setup as well and it runs fine. It just won't run from the batch file. Any ideas? I'm thinking some Windows 7 issue, but can't figure it out.
Thanks,
George
1. Open the GameEx Config Utility
2. Click on Advanced MAME Settings
3. Enter "C:\set49mode\set49mode.exe [ROM]" (without quotes) in the Run on Launch box.
4. Enter "C:\set49mode\set49mode.exe 1943" (without quotes) in the Run on Exit box.
5. Click Save"
On 8/8/2018 at 4:06 AM, Tom Speirs said:
Hi, can you please post the batch file along with your log file and gameex.ini
Many thanks.
Tom.
Here they are.
Thanks,
Topgun
gameex.zip
Actually, it looks like I added support for Set49 later than the post.
You can just use [CONTROL] instead of [ROM] and avoid all that setup but it does still look like you need to install the GP49Wiz software.
