I have an issue that started on PBX 2.65 (Which was stable for me) I then updated to 3.06 and the issue is not resolved.
The issue is that through PBX my nvram file for NBA Fastbreak (nbaf_31.nv) will not update. If I play through the VPX editor (10.5 3479 32 bit), it updates the nvram fine.
3.06 32 bit  is slow as between tables, around 30 seconds per table load, or exit. 2.65 was fast. I have an i5 4490, Win 10 home, GTX 970 4gb OC, 16GB Ram, SSD HD.
I played Bugs Bunny, another Midway table and it updated the nvram. Small sample but it worked.
I have a cabinet, 3 screens, no DOF, SSF and no LED's.
I do not use 3rd party software during gameplay (Teamviewer when not) and I haven't install PinUp Popper,
PinballX.ini
SetupWizard.xml
