Hi,
I've recently updated from PBX 2.74 to both 3.05 (and then 3.06) and the screenshot function does not work. I'm running a 2 screen plus PIN2DMD setup. This happens with both VPX latest beta and VP9 PM5. I've checked both the screengrabs and table images / backglass images folder and no screenshots appear. I've tried this with several tables, both to update an existing screenshot, and to add a new table.
Capturing videos using both game manager and the 'v' key works fine. If I downgrade back to 2.50 (I don't have the 2.74 installer anymore) screenshots work just fine using the old 'S' and 'B' method appearing in screengrabs / screengrabs backglass.
I would appreciate if you could take a look as I don't like using videos in the front end.
Cheers
Rob
PinballX.ini
  • 5 weeks later...
