Hello All,
I updated to Pinball X 3.05 and pinballX crach at stratup, pinballxlite seems to work.
I have this error in the log file:
 Une erreur s'est produite lors de la création du formulaire. Pour plus d'informations, consultez Exception.InnerException. L'erreur est : Classe non enregistrée (Exception de HRESULT : 0x80040154 (REGDB_E_CLASSNOTREG))
22:16:19.4  21/06/2018:     à c.a.a[a](a A_0)
22:16:19.5  21/06/2018:     à c.a.a()
22:16:19.5  21/06/2018:     à PinballX.FrmMain.a(Boolean A_0, Boolean A_1, Boolean A_2, Boolean A_3, Boolean A_4, Boolean A_5)
22:16:19.6  21/06/2018:     à PinballX.FrmMain.b(Boolean A_0, Boolean A_1, Boolean A_2, Boolean A_3)
I have 2 screens and no plugins.
Thanks for your help.
Kaléo.
PinballX.ini
[SETTINGS].log
It may be an issue with DirectX. Which version did you upgrade from?
Id try turning off your run on startup app.
You could try the DirectX9 Runtime web installer.
I have the same problem, PinballX 3.05 does not start.
I have tried to uninstall it completely and reinstall it.
I do not have anything starting with PinballX.
I tried to install DIrectX9 Runtime, but it has been put in seconds, as if it were already there.
Tengo el mismo problema, PinballX 3.05 no inicia.
He probado a desinstalar completamente y volver a instalar.
No tengo puesto nada de inicio con PinballX.
He probado a instalar DIrectX9 Runtime, pero me lo ha puesto en segundos, como si ya estuviera.
[SETTINGS].log
PinballX.ini
I have made a new installation by selecting "Force 32bit installation"
Now it works.
He hecho una nueva instalación seleccionando "Forzar 32Bit instalación"
Ahora funciona.
I have 1 flash.ocx in D:/PinballX and 1 flash.ocx in another folder from 1 old instalation in D:/New Folder/PinballX
But now it works for me, I guess at 32Bit, but it works.
On the other hand, I have seen a video and a new function of GameManager to create system videos, but I have not managed to create systems lists, I have reviewed the forum and I do not see anything about it.
Pero ahora ya me funciona, supongo que a 32Bit, pero funciona.
Por otra parte, he visto un vídeo y una nueva función de GameManager para crear vídeos de sistemas, pero no he conseguido crear listas de sistemas, he revisado el foro y no veo nada al respecto.
I understood that it was to create systems videos, I misunderstood then.
I have already deleted the two files, now I guess I would have to do a new installation without forcing 32bits
Right?
Yes!
After deleting those files I made a new installation without checking 32bits and this time it runs perfectly.
Siiiii!!!
Tras borrar esos archivos he hecho una nueva instalación sin marcar forzar 32bits y en esta ocasión si que se ejecuta perfectamente.
@PcTeknicand @Tom Speirs, Thanks both, deleting Flash.ocx and reinstalling pinballx solved the problem.
I don't remember the version of the previous PinballX... it had maybe one year or more.
Anyway, all is ok now. Thanks again.
Kaléo.
  • 1 month later...
