Gildahl Posted June 14, 2018 Share Posted June 14, 2018 Hi Tom, I just updated to 15.32 and I am experiencing loss of joystick input again (as well as my other two open issues). It's a little different this time. Originally joystick control was gone upon loading GameEx. This time jJoystick works fine at first, but after playing a game for a while and returning to GameEx, joystick control is gone. I use Ultrastick 360s. So to recap open items. 1. Loss of joystick control (but only after returning from a game). 2. Loss of interface sounds after returning from games (game sounds and video snapshot sounds still work). Restarting GameEx gets sound back temporarily. 3. Loss of Daphne game list in my custom menu. Dave log.txt GameEx.ini CustomMenu.ini Link to comment Share on other sites More sharing options...
Tom Speirs Posted June 14, 2018 Share Posted June 14, 2018 Thanks for your patience. Ill try and get to this shortly. Tom. Link to comment Share on other sites More sharing options...
Tom Speirs Posted June 14, 2018 Share Posted June 14, 2018 Hey, I have not looked at the Daphne issue yet, but is it a particular emulator causing a problem as I cant duplicate eh audio or gamepad issue? Link to comment Share on other sites More sharing options...
Gildahl Posted June 14, 2018 Author Share Posted June 14, 2018 I did a little more testing today. The joystick issue is hard to pin down. When I started up today, all was good (joystick & sound), after playing a bit of Asteroids I returned to GameEx and found the joystick not working; however, after a few moments it started working again. After playing some more, most of the time the joystick would be ok after returning to GameEx, but I did encounter one more "delay" of about 5 seconds of dead joystick before it became functional again. So I can see how this might be hard to duplicate. It has definitely never done this sort of thing before 15.30 though. Regarding sound, interface sounds (clicks and chimes) are always fine upon first loading GameEx but are gone for good after returning from pretty much any game. As I reported earlier, sound from video snaps still work in the interface and sound in games is fine, it's only the interface sounds that disappear. Link to comment Share on other sites More sharing options...
Gildahl Posted June 14, 2018 Author Share Posted June 14, 2018 Just to follow-up, I deleted the whole contents of the GameEx folder (just the files in the root, not the subfolders) and replaced the contents with a backup from 15.27 and both the joysticks and sound seem to work fine/normal (unfortunately, however, the Daphne issue is still there). As soon as I revert back to the 15.32 files again, the sound and joystick issues return (I can at least now confirm that when it happens the joystick remains dead for about 5 to 10 seconds after returning from a game). I should also remark that just replacing the GameEx.exe with the 15.27 .exe does not fix the issue, it is only when I replace all the files in c:\GameEx with the ones from 15.27 that the problem goes away. Link to comment Share on other sites More sharing options...
Tom Speirs Posted June 15, 2018 Share Posted June 15, 2018 I did change libraries between those versions so it would explain it. I will have to post you a version with some logging to help troubleshoot the issue. As for audio Ill just try reinitilaing after coming back from game launch. Ill get back to you. Tom. Link to comment Share on other sites More sharing options...
Gildahl Posted July 3, 2018 Author Share Posted July 3, 2018 Hi Tom, Just a note that I updated to 15.34 today and still get loss of interface sound after returning from some games back to GameEx. It doesn't happen with all games, but Visual Pinball X seems to be the most reliable in killing the interface sounds. As before, if I revert the files in the c:\GameEx folder back to those from 15.27, I have no issues. I didn't test extensively, but didn't notice any joystick issues this time, so maybe that's fixed now? I'll follow-up if I see that again. Also, on the Daphne issue that I was having, that seems to be resolved. On a whim I toggled the switch in the Wizard to disable then enable Daphne and the games now show up again, so it was just something funky in the configuration that seems to have happened after a recent update. Link to comment Share on other sites More sharing options...
Tom Speirs Posted July 4, 2018 Share Posted July 4, 2018 Thanks for reporting back. I've not done much on your issues but will try to make audio reinitialize on return from game. Link to comment Share on other sites More sharing options...
Adultery Posted July 11, 2018 Share Posted July 11, 2018 Hi @Tom Speirs: Just to throw my hat in the ring, I have the missing audio when returning from a game as well. Nothing suspicious in the logs. After I run a game and use ESC to exit the emulator, all my GameEx menu sounds are gone. I also lose my pagination controls on the joystick, although the menu nav controls and the confirm/cancel buttons still work. I can reproduce this reliably every time I exit a game. 23:12:33.18 7/10/2018: Opening Configuration File 23:12:33.20 7/10/2018: GameEx: Version 15.34: Starting Log 23:12:33.28 7/10/2018: Windows 10 Pro 64-bit 23:12:33.28 7/10/2018: Aero running 23:12:33.29 7/10/2018: Initializing Vista/Windows 7 volume control 23:12:33.30 7/10/2018: Getting CPU and RAM info 23:12:33.30 7/10/2018: Intel(R) Core(TM) i7-3770K CPU @ 3.50GHz, 32601MB 23:12:33.31 7/10/2018: 3.49Ghz - 8 Cores or CPU's 23:12:33.31 7/10/2018: Running Randomize() 23:12:33.37 7/10/2018: Loading PlugIns 23:12:33.38 7/10/2018: Loaded Plugin:"Game Info Plugin" Version 1.3.6 By Adultery 23:12:33.84 7/10/2018: PlugIn: "Game Info Plugin" Initialized OK 23:12:33.84 7/10/2018: Using Plugin System Version: 1.41 23:12:33.99 7/10/2018: Loaded Plugin:"Game Tagger" Version 1.1.5 By Adultery 23:12:35.69 7/10/2018: PlugIn: "Game Tagger" Initialized OK 23:12:35.70 7/10/2018: Using Plugin System Version: 1.41 23:12:35.71 7/10/2018: Loaded Plugin:"Hi-Score Snapper" Version 1.0.8 By Adultery 23:12:37.10 7/10/2018: PlugIn: "Hi-Score Snapper" Initialized OK 23:12:37.11 7/10/2018: Using Plugin System Version: 1.41 23:12:37.12 7/10/2018: Checking for applications to Launch On Startup 23:12:37.13 7/10/2018: Setting default net connection limit to 15 23:12:37.13 7/10/2018: Running Misc startup tasks 23:12:37.13 7/10/2018: Setting Menu types 23:12:37.14 7/10/2018: Getting Configuration Values 23:12:37.14 7/10/2018: Using Theme: MegaMAME 23:12:37.14 7/10/2018: Checking for alternate Image Directory for Theme: MegaMAME 23:12:37.15 7/10/2018: Launching HideOS.exe 23:12:37.15 7/10/2018: Initialising Video/MNG DLL's 23:12:37.15 7/10/2018: GameEx will check for media insertion (may affect performance) 23:12:37.16 7/10/2018: Hiding Taskbar 23:12:37.16 7/10/2018: Using Cabinet Friendly Control System 23:12:37.17 7/10/2018: Is Media Center running? 23:12:37.18 7/10/2018: Checking/Creating LCD Registry values 23:12:37.18 7/10/2018: Check Media Center Exit/Start Mode 23:12:37.18 7/10/2018: Media Center Mode 2 23:12:37.20 7/10/2018: Video previews on. Warning: Only recommended on modern systems 23:12:37.20 7/10/2018: Custom Game Device Input enabled: Getting custom codes 23:12:37.21 7/10/2018: Snap Delay set to: 4 23:12:37.21 7/10/2018: Get other settings 23:12:37.21 7/10/2018: Set: Find emulator artwork on best match basis 23:12:37.22 7/10/2018: Start work for Form 23:12:37.22 7/10/2018: Getting Original Screen Size 23:12:37.23 7/10/2018: Opening Database Connection 23:12:37.23 7/10/2018: Data Source=C:\GameEx\DATA\data.db3;Pooling=true;FailIfMissing=true 23:12:37.28 7/10/2018: Initializing Component 23:12:37.29 7/10/2018: MAME Path is: E:\Emulators\Mame 23:12:37.30 7/10/2018: MAME EXE file is: mame64.exe 23:12:37.30 7/10/2018: ROM Path is: T:\Roms\MAME\roms 23:12:37.31 7/10/2018: Catver.ini is located at: C:\GameEx\DATA\catver.ini 23:12:37.31 7/10/2018: controls.ini is located at: C:\GameEx\DATA\controls.ini 23:12:37.35 7/10/2018: History.dat is located at: C:\GameEx\DATA\history.dat 23:12:37.35 7/10/2018: nplayers.ini is located at: C:\GameEx\DATA\nplayers.ini 23:12:37.36 7/10/2018: command.dat is located at: C:\GameEx\DATA\command.dat 23:12:37.36 7/10/2018: MAMEinfo.dat is located at: C:\GameEx\DATA\mameinfo.dat 23:12:37.37 7/10/2018: Loading Controls.ini map file 23:12:37.37 7/10/2018: Snap Path is: E:\Artwork\MAME\Snap 23:12:37.37 7/10/2018: Database Snap Path: Not Found 23:12:37.38 7/10/2018: Background Snap Path: Not Found 23:12:37.38 7/10/2018: AVI Snap Path is: E:\Artwork\MAME\Video_MP4 23:12:37.38 7/10/2018: Flyer Path is: E:\Artwork\MAME\Advert 23:12:37.39 7/10/2018: Cabinet Path is: E:\Artwork\MAME\Cabinet 23:12:37.39 7/10/2018: Cabinet 3D Path: Not Found 23:12:37.39 7/10/2018: Title Path is: E:\Artwork\MAME\Title 23:12:37.40 7/10/2018: Title Path is: E:\Artwork\MAME\Logos 23:12:37.40 7/10/2018: PCB Path is: E:\Artwork\MAME\PCB 23:12:37.40 7/10/2018: Artwork Preview Path: Not Found 23:12:37.41 7/10/2018: Panel Path: Not Found 23:12:37.41 7/10/2018: Manual Path is: E:\Artwork\MAME\Manual 23:12:37.41 7/10/2018: Icon Path is: E:\Artwork\MAME\Icon 23:12:37.42 7/10/2018: Marquee Path is: E:\Artwork\MAME\Marquee 23:12:37.42 7/10/2018: Applying Language/Text 23:12:37.43 7/10/2018: Text/Language: English 23:12:37.44 7/10/2018: Loading Language/Text 23:12:37.45 7/10/2018: Loading Addins 23:12:37.45 7/10/2018: Using Version 3 Themes Animations 23:12:37.45 7/10/2018: Retrieving resolution setting 23:12:37.46 7/10/2018: Using General Font: Tahoma 23:12:37.46 7/10/2018: Using Title Font: Tahoma 23:12:37.47 7/10/2018: GameEx will try to reduce CPU usage 23:12:37.52 7/10/2018: Initialising Direct3D 23:12:37.74 7/10/2018: Applying GameEx is Loading Image 23:12:37.77 7/10/2018: Setting Resolution to 1920x1080 32 bit color 23:12:37.78 7/10/2018: Creating Surfaces 23:12:37.93 7/10/2018: Creating Back Buffer 23:12:37.94 7/10/2018: Version 2 Theme being used. Loading. 23:12:37.95 7/10/2018: Loading Button Data 23:12:37.95 7/10/2018: Loading Font Data 23:12:37.95 7/10/2018: Loading Layout Data 23:12:37.96 7/10/2018: Loading Taskbar Data 23:12:37.96 7/10/2018: Loading graphic Surfaces 23:12:37.97 7/10/2018: Display is running at: 1920x1080 32bit color, 60hz 23:12:37.97 7/10/2018: Adapter: NVIDIA GeForce GT 730 23:12:37.98 7/10/2018: Max texture size: 16384x16384 23:12:37.98 7/10/2018: Available texture memory: 4056MB 23:12:38.01 7/10/2018: Available video memory: 2176MB 23:12:38.09 7/10/2018: Initialising Bass Audio Library 23:12:38.11 7/10/2018: Creating Surfaces Misc and Dialogs 23:12:38.16 7/10/2018: Creating Surfaces Volume 23:12:38.16 7/10/2018: Creating Surfaces Arrows 23:12:38.17 7/10/2018: Creating Surfaces GameEXlogo Text 23:12:38.17 7/10/2018: Creating Surfaces Toolbar 23:12:38.21 7/10/2018: Creating Surfaces Toolbar Controls 23:12:38.22 7/10/2018: Creating Surfaces Backgrounds 23:12:38.23 7/10/2018: Creating Surfaces GameEx Logo 23:12:38.23 7/10/2018: Creating Surface Unselected 23:12:38.24 7/10/2018: Creating Surfaces Snaps 23:12:38.24 7/10/2018: Creating Surfaces Menu and List Bars 23:12:38.28 7/10/2018: Creating Fonts 23:12:38.29 7/10/2018: Creating Game Font 23:12:38.33 7/10/2018: Creating Game Font Faded 23:12:38.36 7/10/2018: Creating Title Font 23:12:38.37 7/10/2018: Restoring Title Font From Cache 23:12:38.45 7/10/2018: Creating Font Black 23:12:38.47 7/10/2018: Creating Font Black Small 23:12:38.51 7/10/2018: Fonts Created Succesfully 23:12:38.52 7/10/2018: Loading News Feed: http://www.gameex.net/gameexnews.xml 23:12:39.31 7/10/2018: 31MB Video Memory Used 23:12:39.32 7/10/2018: Initial Emulator Load 23:12:39.35 7/10/2018: Loading Custom Emulators 23:12:39.35 7/10/2018: Loading Emulator 1: Nintendo NES 23:12:39.37 7/10/2018: Checking if Steam enabled 23:12:39.38 7/10/2018: Steam is installed correctly 23:12:39.38 7/10/2018: Found Steam Base Install Folder: c:/program files (x86)/steam 23:12:39.38 7/10/2018: Found Steam Base Install Folder: D:\\SteamLibrary 23:12:39.39 7/10/2018: Found Steam Game: River City Ransom: Underground. AppID=422810. Location:C:\Program Files (x86)\Steam\steamapps\common\River City Ransom Underground 23:12:39.40 7/10/2018: Found Steam Game: Sonic & All-Stars Racing Transformed Collection. AppID=212480. Location:D:\SteamLibrary\steamapps\common\Sonic & All-Stars Racing Transformed 23:12:39.40 7/10/2018: Found Steam Game: Pinball Arcade. AppID=238260. Location:D:\SteamLibrary\steamapps\common\PinballArcade 23:12:39.40 7/10/2018: Found Steam Game: Broforce. AppID=274190. Location:D:\SteamLibrary\steamapps\common\Broforce 23:12:39.41 7/10/2018: Found Steam Game: 8BitBoy. AppID=296910. Location:D:\SteamLibrary\steamapps\common\8BitBoy 23:12:39.41 7/10/2018: Found Steam games. Steam enabled. 23:12:39.42 7/10/2018: Checking if Origin enabled 23:12:39.43 7/10/2018: Cannot find origin executable 23:12:39.44 7/10/2018: Checking if Uplay enabled 23:12:39.44 7/10/2018: Cannot find UPlay executable 23:12:39.67 7/10/2018: MAME CMD options: -nowindow -joy -skip_gameinfo -keyboardprovider dinput -noka 23:12:39.70 7/10/2018: Initialising DirectInput for Gamepad support 23:12:39.75 7/10/2018: Using Device Controller (XBOX 360 For Windows) 23:12:39.76 7/10/2018: Loading Start Page 23:12:39.82 7/10/2018: Initializing MCE Remote 23:12:39.82 7/10/2018: Playing intro sound file 23:12:39.83 7/10/2018: Initialization OK! Starting GameEx! 23:12:39.84 7/10/2018: Testing Main Loop Once: Processing Frame 23:12:40.00 7/10/2018: Testing Main Loop Once: Main Loop ran successfully 23:12:43.50 7/10/2018: Attempting to load game list 23:12:43.61 7/10/2018: Validating: Emulator_1: Custom Background: back-nintendo_nes.png 23:12:43.61 7/10/2018: Validating: Emulator_1: Snap Path: E:\Artwork\Nintendo_NES\Snap 23:12:43.62 7/10/2018: Validating: Emulator_1: Video Snap Path: E:\Artwork\Nintendo_NES\Video_MP4 23:12:43.62 7/10/2018: Validating: Emulator_1: Database: [Console] Nintendo NES 23:12:43.62 7/10/2018: Validating: Emulator_1: Title Snap Path: E:\Artwork\Nintendo_NES\Title 23:12:43.63 7/10/2018: Validating: Emulator_1: Logo Snap Path: E:\Artwork\Nintendo_NES\Logos 23:12:43.63 7/10/2018: Validating: Emulator_1: Box Art Path: E:\Artwork\Nintendo_NES\Box 23:12:43.63 7/10/2018: Validating: Emulator_1: Cart Art Path: E:\Artwork\Nintendo_NES\Cart 23:12:43.64 7/10/2018: Validating: Emulator_1: Manual Path: E:\Artwork\Nintendo_NES\Manual 23:12:43.88 7/10/2018: Not Restoring Emulator Database From Cache: 1 23:12:45.39 7/10/2018: Restoring Cached ICONS from File 23:12:48.03 7/10/2018: Loading News Feed: http://www.1up.com/rss/latestUpdates?event=&platform= 23:12:54.83 7/10/2018: Running: cmd.exe /c C: retroarch.exe -L "C:\Emulators\RetroArch\cores\fceumm_libretro.dll" "T:\Roms\Nintendo\Nintendo Entertainment System\Super Mario Bros. 3 (USA) (Rev A).7z" -c "C:\Emulators\RetroArch\retroarch.cfg" -f 23:12:55.10 7/10/2018: Shutting down display 23:13:19.43 7/10/2018: Writing Stats 23:13:19.46 7/10/2018: Plugin: Game Exit 23:13:19.75 7/10/2018: Plugin: Process Commands 23:13:19.75 7/10/2018: Refreshing Keyboard 23:13:19.89 7/10/2018: Initialising Audio 23:13:20.20 7/10/2018: Restoring Window 23:13:20.21 7/10/2018: Reinitializing Graphics System 23:13:20.37 7/10/2018: initialized display 23:13:20.38 7/10/2018: Display is running at: 1920x1080 32bit color, 60hz 23:13:20.75 7/10/2018: Loading News Feed: http://www.1up.com/rss/latestUpdates?event=&platform= 23:13:21.50 7/10/2018: Reloading Game Info Page 23:13:21.72 7/10/2018: Returning to GameEx 23:13:26.93 7/10/2018: Exiting GameEx! 23:13:26.94 7/10/2018: Closing HideOS.exe 23:13:29.27 7/10/2018: Disposing all videos 23:13:29.27 7/10/2018: Deleting temporary Karaoke videos 23:13:29.28 7/10/2018: Disposing Image List 23:13:29.28 7/10/2018: Disposing Fonts 23:13:29.28 7/10/2018: Disposing Surfaces 23:13:29.30 7/10/2018: Saving Settings 23:13:29.30 7/10/2018: Saving Settings 23:13:29.31 7/10/2018: Shutting down Bass 23:13:29.36 7/10/2018: Disposing Plugins 23:13:29.37 7/10/2018: Disposing Plugins 23:13:29.37 7/10/2018: Closing database connection 23:13:29.38 7/10/2018: Checking for applications to Launch On Exit 23:13:29.39 7/10/2018: Logging out of GameEx Online 23:13:30.02 7/10/2018: Bye Link to comment Share on other sites More sharing options...
thurmansevolution Posted July 11, 2018 Share Posted July 11, 2018 Hello and Good Morning/Afternoon/Evening! :D I hope all is going well for everyone in the GameEx family. It's been a little while since I was last active, mostly due to life going a bit fast (switching jobs, remarried, school) - I've been getting more into the IT field, and now work in the IT department of a university here in Mississippi. Anyway lol... I came across this post, and saw something that may or may not help out, at least with the audio. I was having a similar audio issue in the latest versions of GameEx. I normally have a music playlist going outside of running a game. After exiting a game and returning to GameEx, sometimes the music volume would be really low, to the point to where it sounds muffled....and there would be no menu sounds. Exiting and restarting GameEx would fix this temporarily, until exiting another game where it would randomly occur again. When troubleshooting, there was something I noticed within the GameEx logs....when exiting a game and returning to the FE, this issue happened only when GameEx would "Initialize Audio". When GameEx didn't initialize audio, the audio would work normally. I reverted to an older, backed up version of GameEx as a work around. I seen something in the logs that was posted by Adultery: 23:13:19.89 7/10/2018: Initialising Audio I hope any of this information helps :). Link to comment Share on other sites More sharing options...
DazzleHP Posted July 15, 2018 Share Posted July 15, 2018 On 7/11/2018 at 3:16 PM, thurmansevolution said: hope any of this information helps :). All information helps my man, even if not immediately. Thanks for the share. Link to comment Share on other sites More sharing options...
Tom Speirs Posted August 4, 2018 Share Posted August 4, 2018 Sorry for the delay. I will get to this very shortly. Link to comment Share on other sites More sharing options...
Tom Speirs Posted August 20, 2018 Share Posted August 20, 2018 The audio issues are fixed in the latest release. Now available. Im not sure about the gamepad issues right now. Any more information would be helpful. Link to comment Share on other sites More sharing options...
Adultery Posted August 20, 2018 Share Posted August 20, 2018 I meant to update you on this, mine was a faulty USB port. I replaced the hub and I'm not having an issue any longer. Was watching it in Function Logger and my key presses are all processing fine. I'll holler back about the audio after I play around in there some. Link to comment Share on other sites More sharing options...
Gildahl Posted August 21, 2018 Author Share Posted August 21, 2018 Should have a chance to try out the audio fix tomorrow. Link to comment Share on other sites More sharing options...
Gildahl Posted August 22, 2018 Author Share Posted August 22, 2018 Hi Tom, Woo-hoo. 15.35 does appear to fix the audio re-init problem. Thanks for that. With that said, I have another issues that I will post in a separate thread that are still preventing me from using the latest build. It has some relation to the game controller issue and might provide some more info toward fixing that. Dave Link to comment Share on other sites More sharing options...
