This may be a very simple (and stupid) issue I am having... I cannot get Settings in PinballX to accept Joystick Codes from my ZebsBoard Digital Plunger.  Everything works fine outside of PinballX, and PinballX seems to function fine with a keyboard.  In Settings, when I try to configure the buttons on my cabinet, the program automatically sets to a weird axis before I can press the button I am trying to configure.  I tried playing with different codes within the PinballX.ini file, but nothing seems to work.  I must have something incorrect within PinballX as I know the cabinet buttons work as expected directly in an emulator, and they show the correct character(s) in Notepad.  Any suggestions would be greatly appreciated, thanks in advance!  Below are the log.txt and PinballX.ini files... the PinballX.ini will show a mess with the joystick codes which is what I have been playing with.
Not sure if it will help, but the Digital Plunger is hardcoded for the Standard button layout for Visual Pinball:
Left Flipper = L Shift
Right Flipper = R Shift
etc.
PinballX.ini
Mine does this as well and its why I moved from pbx to pinup.  Hope you can get this worked out I was never able to solve it
Sorry for the delayed response, I was out of town and not able to verify until tonight.  It sets (regardless of what button I push, in fact I think it does it as soon as I hit the "...") the following:  [JOYCODE_1_RZAXIS_POS_SWITCH]
