Whenever I got to create videos for my MAME games using the Create MAME Videos program that comes with GameEx I get an an error to the effect that my collection was modified. I've tried it with the videos that I have created previously in the folder (c:\videos as you can see from the log) or nothing in the folder and it still messes up. Any ideas?
17:02:45.4 8/14/2006: GameEx: Version 6.54: Starting Log
17:02:45.4 8/14/2006: Operating System Platform: Win32NT
17:02:45.4 8/14/2006: Operating System Name: Windows XP
17:02:45.4 8/14/2006: Operating System Version: 5.1.2600
17:02:45.4 8/14/2006: Checking for versions of .net Framework installed
17:02:45.4 8/14/2006: .net Framework 1.1 Installed
17:02:45.4 8/14/2006: .net Framework 2.0 Installed
17:02:45.4 8/14/2006: Checking Registration
17:02:45.4 8/14/2006: Running Randomize()
17:02:45.4 8/14/2006: Checking for applications to Launch On Startup
17:02:45.4 8/14/2006: Initialising Video/MNG DLL's
17:02:45.4 8/14/2006: Running Misc startup tasks
17:02:45.4 8/14/2006: Setting Menu types
17:02:45.4 8/14/2006: Opening Configuration File
17:02:45.4 8/14/2006: Getting Configuration Values
17:02:45.4 8/14/2006: Launching HideOS.exe
17:02:45.4 8/14/2006: Hiding Taskbar
17:02:45.4 8/14/2006: Is Media Center running?
17:02:45.4 8/14/2006: Checking/Creating LCD Registry values
17:02:45.4 8/14/2006: Check Media Center Exit/Start Mode
17:02:45.4 8/14/2006: Media Center Mode 0
17:02:45.4 8/14/2006: Text/Language: English
17:02:45.4 8/14/2006: Applying Language/Text
17:02:45.5 8/14/2006: Custom Keyboard Input enabled: Getting custom codes
17:02:45.5 8/14/2006: Snap Delay set to: 5
17:02:45.5 8/14/2006: Get other settings
17:02:45.5 8/14/2006: SlikStik support enabled
17:02:45.5 8/14/2006: Using DirectInput for keyboard input
17:02:45.5 8/14/2006: Start work for Form
17:02:45.5 8/14/2006: Getting Original Screen Size
17:02:45.5 8/14/2006: Loading ICON
17:02:45.5 8/14/2006: Initializing Component
17:02:45.5 8/14/2006: Initialising Bass Audio Library
17:02:46.0 8/14/2006: Loading default loading screen
17:02:46.0 8/14/2006: Using 3D Alpha Blended Animations. This could be slow
17:02:46.0 8/14/2006: Using General Font: Trebuchet MS
17:02:46.0 8/14/2006: Using Title Font: Trebuchet MS
17:02:46.0 8/14/2006: Starting GameExtender on: 127.0.0.1:8383
17:02:46.0 8/14/2006: Starting GameExtender Publisher
17:02:46.0 8/14/2006: Initialising DirectDraw
17:02:46.0 8/14/2006: Applying GameEx is Loading Image
17:02:46.6 8/14/2006: Creating DirectDraw Device
17:02:46.6 8/14/2006: Using Device: XGI Volari Family
17:02:46.8 8/14/2006: Creating DirectDraw Surfaces
17:02:46.8 8/14/2006: Creating Primary Surface - Windowed Mode
17:02:46.8 8/14/2006: Creating Back Buffer
17:02:46.9 8/14/2006: Loading graphic surfaces
17:02:46.9 8/14/2006: Creating Surfaces Misc and Dialogs
17:02:47.0 8/14/2006: Creating Surface Volume
17:02:47.0 8/14/2006: Creating Surfaces Arrows
17:02:47.1 8/14/2006: Creating Surfaces GameEXlogo Text
17:02:47.1 8/14/2006: Creating Surfaces Toolbar
17:02:47.2 8/14/2006: Creating Surfaces Backgrounds
17:02:49.1 8/14/2006: Creating Surfaces Toolbar Controls
17:02:49.2 8/14/2006: Creating Surfaces GameEx Logo
17:02:49.2 8/14/2006: Creating Surfaces Home & Exit
17:02:49.2 8/14/2006: Creating Surfaces Snaps
17:02:49.3 8/14/2006: Creating Surfaces Menu and List Bars
17:02:49.5 8/14/2006: Creating Fonts
17:02:49.5 8/14/2006: Creating Menu Font
17:02:50.8 8/14/2006: Creating Game Font
17:02:51.7 8/14/2006: Creating Font Black
17:02:51.8 8/14/2006: Creating Font Black Small
17:02:51.9 8/14/2006: Creating Game Font Faded
17:02:52.8 8/14/2006: Creating Title Font
17:02:55.9 8/14/2006: Creating Control Panel Font
17:02:56.7 8/14/2006: Fonts Created Succesfully
17:02:56.7 8/14/2006: MAME Path is: D:\MAME
17:02:56.7 8/14/2006: MAME EXE file is: Mame32.exe
17:02:56.7 8/14/2006: ROM Path is: D:\MAME\roms
17:02:56.7 8/14/2006: Catver.ini is located at: D:\MAME\catver.ini
17:02:56.7 8/14/2006: controls.ini is located at: D:\MAME\controls.ini
17:02:56.7 8/14/2006: History.dat is located at: D:\MAME\history.dat
17:02:56.7 8/14/2006: nplayers.ini is located at: D:\MAME\nplayers.ini
17:02:56.7 8/14/2006: MAMEinfo.dat is located at: D:\MAME\mameinfo.dat
17:02:56.7 8/14/2006: Loading Controls.ini map file
17:02:56.7 8/14/2006: Loading Custom Emulators
17:02:56.7 8/14/2006: Loading Emulator 1: Nintendo Enertainment System
17:02:56.7 8/14/2006: Loading Emulator 2: Super Nintendo
17:02:56.8 8/14/2006: Loading Emulator 3: Sega Genesis
17:02:56.8 8/14/2006: Loading Emulator 4: Sega Game Gear
17:02:56.8 8/14/2006: Loading Emulator 5: Atari 2600 Games
17:02:56.9 8/14/2006: Loading Emulator 7: Pinball Games
17:02:57.1 8/14/2006: Snap Path is: D:\MAME\snap
17:02:57.1 8/14/2006: AVI Snap Path is: c:\videos
17:02:57.1 8/14/2006: Flyer Path is: D:\MAME\flyers
17:02:57.1 8/14/2006: Cabinet Path is: D:\MAME\cabinets
17:02:57.1 8/14/2006: Title Path is: D:\MAME\titles
17:02:57.1 8/14/2006: Panel Path is: D:\MAME\cpanel
17:02:57.1 8/14/2006: Icon Path is: D:\MAME\icons
17:02:57.1 8/14/2006: Marquee Path is: D:\MAME\marquees
17:02:57.1 8/14/2006: MAME CMD options: -triplebuffer -nowindow -joy
17:02:57.1 8/14/2006: Attempting to load game list
17:02:57.4 8/14/2006: Error: 5 - Collection was modified; enumeration operation may not execute.
17:02:57.4 8/14/2006: ERRORS DETECTED: EXITING
I still get the exact same error with 6.55.
Yeah, the fix was actually for another issues with creating videos, which I broke a few versions back.
I have looked into your issue in the code, but really cannot see what the issue could be. Its very strange.
Does GameEx work ok normally? Do you get as far as the message box asking to confirm?
Thanks for looking into it. Yeah I thought it was wierd also. GameEx works ok normally, except it won't run maximized. I don't get a message box asking me to confirm anyting.
Also I wanted to mention that when I start GameEx with windows (from startup) it defaults to being minimized in the taskbar, even though I've selected in the properties box to run maximized, (in both GameEx and the shortcut in windows)
