Themes/Languages
Guest Archived From Old Forum
23rd January 2005 - Version 3.00 of GameEx available
Now has full Themes and Multiple Language support hence the jump in
version to 3.00.
Could Translation volunteers and Theme authors, please download the
Alpha Theme Pack, and modify the theme.ini and graphics files as
required.
If you wish to create a theme, copy one of the existing directories
in \THEMES\ and Modify graphics and theme.ini as required.
If a setting exists in theme.ini it will be used instead of the
setting in GameEx.ini
The Naming Convention for Themes is 'Language - Name'
'Default - Name' is used when the Theme.ini does not contains
language settings.
'Language - Default' is used when Graphics are not changes, and
theme.ini only contains language settings.
All the Text/Language values should be in the [TEXT] section of
GameEx.ini and Theme.ini
Specify which theme to use in the Configuration tool, under Basic
Settings.
Added setting to make Dialog Text White.
Configuration tool enhanced with Font Picker, Brightness and Volume
Picker.
If a setting is a drop down in Configuration, and has no value, this
will now be selected as an empty value in the drop down, and not the
first available option.
Better Mouse Wheel support.
In regards to testing the Install on foreign versions of MCE. What I
really need to know is where the GameEx Shortcut is to go so it is
available from the MCE More Programs Module.
On an English System it is here:
{commonstartmenu}\Programs\Accessories\MEDIA Center\MEDIA Center
Programs\
