Instant sheller problem - Boot to explorer instead of application.
Hi!
I have facing some problems using instant sheller. I used mala as front end and i point it to mala.exe in instant sheller app. Instant sheller hides windows 7 (32 bits version) correctly, but the problem is that it boots directly to windows explorer instead of mala. i have tried to boot with other exe applications and it is the same effect (boots to explorer instead of application).
Do you know the reason?? What is the problem??
Thanks in advance.
