Hey Guys,
maybe anyone can help me.
I would like to play different Emulators with different gamepads.
For example for Supernintendo -Emulation, i would like to use the Snes -Gamepad from 8bitdo (SNES/SFC30.
It works so far but my Proplem is to exit the emulator and go back to Gameex.
I have defenied in the input-options a exit-combination for my also used Xbox360 -Controller.
This works, but i can not define another exit combination for the 8bitdo -Gamepad.
Is it somehow possible, to defnine several exit-combinations for different gamepads?
regards
retroplayer
Hi there!
I have an exit combo in Xpadder to exit my emulators, meaning I use a keyboard combo and then map that through Xpadder using emulator profiles. I don't think you can make different types of controllers each have their own combos unfortunately. You can always put in a feature request.
8 minutes ago, Adultery said:
Hi there!
That was my apprehension;)
I also had the the thought to map a keyboard-key to a gamepad-combination for goeing back to gameex.
Maybe its possible with the mentioned tool xpadder. But since xpadder is not free anymore, i don t used it.
Nevertheless, thanks for trying to help!
greetings
