I run pinballx in a 2 monitor setup & have selected vpinball992 as default in pinballx settings, however i have vpx tables too,
i have seperate xml files 1 for vpt tables which are loaded with vpinball992
The other xml file is for VPX tables, so i added     <alternateexe>VPinballX.exe</alternateexe> as last line for each table in visual pinball X.xml  so it starts with vpinballx.
That works fine, but the vpinballx window is popping up in pinballx while loading.   Is there a way to keep it on background while loading?
I searched in settings, but couldn't find it.
no you have to use an ahk script to hide it if you want a clean vpx boot. this blacks the screen out until vpx starts
download autohotkey
open a new txt file, put this code in it
Gui +AlwaysOnTop -Caption +ToolWindow -border
Gui Color, 0
Gui, Show, % "w" 6000 " h" 3000, Black Screen
Sleep 16000
GUI Destroy
exitapp
the sleep is in second so 16000 = 16 sec, tweak as needed
save the file as .ahk
right click and you will see compile.exe
point the launch before to this file.
Thanks for replying, i keep that in mind.
The problem was, i had 2 functions on 1 Button. I changed that & the problem is solved.
Next problem i have when quiting a table, sometimes the window pops up Pinball9 or X has ended. Clicking on it closes the window, but it is annoying.
Can this be fixed?
