With the latest 2.64 I'm encountering an error the second and subsequent times I attempt to launch a PBFX2 table.  First time: no problems.  The error I receive is:
Launching PBFX2 directly before or after the problem works fine.
Exiting PinballX and relaunching works as well (the first time only).
Going back to 2.50 works fine as well.
I installed the latest NVIDIA drivers and installed DirectX again.
DXDiag indicates no problems.
No Application errors in the Windows event log.
Attached my log.txt file and PinballX.ini files.
Any ideers?
PinballX.ini
  Quote
Best just to roll back to 2.50 for now. I'm offering it as default. 2.64 has quite a few issues I need to address.
I figured that's why you rolled back versions.  I've been testing/running on the "2.64 leak patch" you sent me (everyday since then) and it's been working great, no issues.  However, I'm only using Visual Pinball 9/10 tables. I wonder if it's because of the Video Card / DirectX combo or just lucky since I didn't try anything fancy :)
Either way, thanks for the work you put in!
No worries. Obviously as usual the project is in active development so I will get to it soon but yes there seem to be some directx conflicts for some setups. It works fins for me too but I am a bit behind also.
