So, I've been using PinballX for about 2 months now. Never had any issue's with it loading the program. I have it set to launch when windows starts and it use to launch just fine.
I added some VisualX tables to the xml database file. I tested all the tables and they worked in the XPX program. So I decide to reboot my machine so that everything should run smoother and the only process will be PinballX that is running.
Now PinballX no longer launches. It tries to and then it abruptly stops. The screen flickers with the pinball x windows. I don't get an error. It just crashes. So then when I try to launch pinball by itself. Same thing. It just crashes. I didn't make any changes to the settings. And I even deleted the recently added tables.
I need help, as I don't want to do a fresh install. I just want this to work as its a great front end software.
Forgot to mention I am running windows 10. But, I don't think my machine got any updates that could interfere with it.
This really stinks as I was just starting to really dial in all my custom settings.
okay... So I narrowed it down. It appears that when I have visual pinball x enabled, that is what is causeing it to crash. But, I had this enabled for like 25 tables. ANd I just added a few and then it no longer works. As stated I tried deleting the tables that I added in the database file and it still causes the program to crash. But, I can run the program if I disable the VPX tables from loading in the other systtems options...
I really need VPX to work... And now on top of that my b2s backglass settings are all kinds of messed up. I can't get it to just appear on the one proper screen... This seems like a totally stupid error. WOULD REALLY LIKE SOME HELP! Cos this is driving me up the wall.
Okay... Good news. I fixed my Backglass issues. For some strange reason I had to rerun the b2s application and change the resolution in there to the proper one. Don't know how that forgot...
But, I still can't get PinballX to launch when I have VPX enabled. Seems really strange. Again. Would really appreciate help, as there are a lot of really nice VPX tables and I want to use them.
Alright. I figured it out. I had some characters wrong in my database file. All fixed and working now...
Can't believe that happened. I always copy and paste my edits... Must have messed up.... But all is good now. Thanks.
