I have a very modern/fast machine and when I first installed Gamex it loaded right up. I just want to use it for Daphne and don't even have any MAME Stuff installed. I noodled with settings and couldn't get Gamex to run again. So I uninstalled and reinstalled (made sure that config folder was cleared before reinstalling).
Now all I get is the "Nag" message for a few seconds, a black screen, then the game kicks out.
And yes, I tried searching forums/FAQ for info but didn't find anything. (Feel free to point out the obvious to me! :)
Here's the log file - Looks like it starts and kicks out immediately. Thanks in advance.
21:30:15.9 7/25/2006: GameEx: Version 6.49: Starting Log
21:30:15.9 7/25/2006: Operating System Platform: Win32NT
21:30:15.9 7/25/2006: Operating System Name: Windows XP
21:30:15.9 7/25/2006: Operating System Version: 5.1.2600
21:30:15.9 7/25/2006: Checking for versions of .net Framework installed
21:30:15.9 7/25/2006: .net Framework 1.1 Installed
21:30:15.9 7/25/2006: Checking Registration
21:30:15.9 7/25/2006: Running Randomize()
21:30:15.9 7/25/2006: Checking for applications to Launch On Startup
21:30:15.9 7/25/2006: Initialising Video/MNG DLL's
21:30:15.9 7/25/2006: Running Misc startup tasks
21:30:15.9 7/25/2006: Setting Menu types
21:30:15.9 7/25/2006: Opening Configuration File
21:30:15.9 7/25/2006: Getting Configuration Values
21:30:15.9 7/25/2006: Using Theme: Default - MCE Glossy
21:30:15.9 7/25/2006: Checking for alternate Image Directory for Theme: Default - MCE Glossy
21:30:15.9 7/25/2006: Launching HideOS.exe
21:30:15.9 7/25/2006: Hiding Taskbar
21:30:15.9 7/25/2006: Is Media Center running?
21:30:15.9 7/25/2006: Checking/Creating LCD Registry values
21:30:15.9 7/25/2006: Check Media Center Exit/Start Mode
21:30:15.9 7/25/2006: Media Center Mode 2
21:30:16.0 7/25/2006: Text/Language: English
21:30:16.0 7/25/2006: Applying Language/Text
21:30:16.0 7/25/2006: Snap Delay set to: 1
21:30:16.0 7/25/2006: Get other settings
21:30:16.0 7/25/2006: Set: Find emulator artwork on best match basis
21:30:16.0 7/25/2006: Start work for Form
21:30:16.1 7/25/2006: Getting Original Screen Size
21:30:16.1 7/25/2006: Loading ICON
21:30:16.1 7/25/2006: Initializing Component
21:30:16.2 7/25/2006: Initialising Bass Audio Library
21:30:16.3 7/25/2006: Loading default loading screen
21:30:16.3 7/25/2006: Using 2D Animations
21:30:16.3 7/25/2006: Using General Font: Trebuchet MS
21:30:16.3 7/25/2006: Using Title Font: Trebuchet MS
21:30:16.3 7/25/2006: Initialising DirectDraw
21:30:16.4 7/25/2006: Creating DirectDraw Device
21:30:16.4 7/25/2006: Using Device: Mobile Intel® 945GM Express Chipset Family
21:30:16.4 7/25/2006: Setting Resolution to 800x600 32 bit color
21:30:16.6 7/25/2006: Creating DirectDraw Surfaces
21:30:16.6 7/25/2006: Creating Primary Surface - Full Screen Mode
21:30:16.6 7/25/2006: Creating Back Buffer
21:30:16.7 7/25/2006: Loading graphic surfaces
21:30:16.7 7/25/2006: Creating Surfaces Misc and Dialogs
21:30:16.7 7/25/2006: Creating Surface Volume
21:30:16.7 7/25/2006: Creating Surfaces Arrows
21:30:16.7 7/25/2006: Creating Surfaces GameEXlogo Text
21:30:16.8 7/25/2006: Creating Surfaces Toolbar
21:30:16.8 7/25/2006: Creating Surfaces Backgrounds
21:30:17.4 7/25/2006: Creating Surfaces Toolbar Controls
21:30:17.4 7/25/2006: Creating Surfaces GameEx Logo
21:30:17.4 7/25/2006: Creating Surfaces Home & Exit
21:30:17.4 7/25/2006: Creating Surfaces Snaps
21:30:17.4 7/25/2006: Creating Surfaces Menu and List Bars
21:30:17.5 7/25/2006: Creating Fonts
21:30:17.5 7/25/2006: Creating Menu Font
21:30:17.6 7/25/2006: Creating Game Font
21:30:17.6 7/25/2006: Creating Font Black
21:30:17.8 7/25/2006: Creating Font Black Small
21:30:17.9 7/25/2006: Creating Game Font Faded
21:30:17.9 7/25/2006: Creating Title Font
21:30:18.2 7/25/2006: Creating Control Panel Font
21:30:18.5 7/25/2006: Fonts Created Succesfully
21:30:22.8 7/25/2006: Initialization OK! Starting GameEx!
21:30:22.8 7/25/2006: Exiting GameEx!
21:30:22.8 7/25/2006: Saving Settings
21:30:24.7 7/25/2006: Checking for applications to Launch On Exit
You have to manually add each game for Daphne, if that's all you're using GameEx for, what's the point of using it? Why not just make MC shortcuts or something to that effect? You have to manually set up each game anyways.
As far as the problem goes, go into the configuration, disable everything, see if it starts up, if it does, enable what you want one at a time (which will be short if all you are using it for is Daphne), then you should know where your problem is.
Most of the time when GameEx fails to load for me, it's because I have an incorrect path to the roms. If it can't find the roms, it kicks out.
