First off I am in love w the Pinballx front end.
I got almost everything working on the first try, however TPA has since refused to launch through pbx.
I was trying to adjust settings in TPA config (big mistake).  I changed them back / no go
tried uninstalling and reinstalling TPA along w Pinballx
when I try to launch from the game manager it states game not found.
Everything else launches as it should.  I’ve changed nothing in the PBX settings.
Please help me from banging my head against the wall.
thank you
Sorry it has taken me a while to get back w you. (Traveling musician)
you are correct about using steam.
 I will try to do a screen capture today however it usually just goes to a black screen
 I have noticed it giving me a resolution error and asking me to click OK or cancel. When I have seen that error it is hidden under the playfield and can’t be accessed until I exit Pinballx.
Is there a specific configuration for TPA perhaps?
Appreciate your time very much. Thank you
So I decided to readjust my configuration of TPA to its maximum setting and left it at  fullscreen. I then put my play-field in portrait mode in my pc display settings to make sure it was running ok.
 Thought I would try it again through pinball X after I put my playfield back in landscape and it worked !!!!
It is not calling up the correct tables but I’m perfectly OK with one problem at a time
