im using mouse emulation on a gamepad it works but i would like to change the mouse from the thumb stick to the arrow pad just wondering if/how i could do this?
all gamepads that are liek the PS2 controllers should have one, even if it's a generic one.
personally I recommend a logitech rumblepad 2, the program that comes with it allows you to map any one key, a cycle of keys, a combination of commands, a cycle of keys and/or combination of commands, & it launches automatically whenever whatever program/game is launched. also allows you to map mouse movements & keys to controller, very nice controller.
I don't suppose your gamepad has the option to switch between the two? Mine have a switch that toggles the analog/digital pads.
i been playing around and i can change what the keys are like use the can use the arrow pad as thumb stick button but it would mean i would have to change it back each time
