ok, first of all hi to all of you guys, and to tom who does a great job with this frontend :D
now i have a big problem with dreamcast ive looked trough the configs and trying to get dreamcast to work, but its all chinese to me. i aint the brightest guy and its just to hard to get it to work. i wonder if someone would have the time to write it down here step by step :( ( really step by step). i do have to mention that i am planning to insert every single dc game that was made in the usa as i have the full set. is this possible to do in gameex? or will it be just to much work to configure it all? (there are about 270 games)
thx guys
thx guys
What emulator are you using? As far as I knew, the latest version of chankast is pretty old (has not been updated in a while) and not all games are playable. I could be wrong.
In any case, use the tutorial and config from Headkaze....you will need chankast_launch and Daemon tools. His tutorial is really step-by-step. Is this the one you were having trouble following?
http://www.gameex.info/forums/index.php?showtopic=752
eg
dreamcast kinda works now, but i have a different problem now. with visual pinball i have setup everything but when i load a game i have to click on a screen that asks me if i have the rights to play the game, i can choos between "i can" and "i can't" anyone knows how to fix this?
try setup send key using tab's and spacebar to select the tick box should be possbile you will have to time how long it takes and add a bit, for it to get to that stage though
i havnt tryed it as i dont use vpinball in gameex
omg im going crazy here, now that pinball is working perfect im having a problem again with dreamcast. i used the chankast_launch utility and set up everything as it is supposed to be, i tested it and it loads the image fine, aswell as starting up chankast but when chankast launches i get an error message saying "ERROR: NO INPUT PLUGIN COULD BE FOUND" or else chankast just freezes. i do have a controller plugin installed
Your controller is mapped through Chankast? If you load Chankast independantly you should be able to map your controller there and everything should be hunky-dorey.
Hope that helps! :)
